  New Posts New Posts RSS Feed: Sway.  Another question
Topic ClosedSway. Another question
Direct Link To This Post Topic: Sway. Another question
    Posted: 03 Feb 2017 at 6:42pm
I think 85 mph is on the sidewalls of the tires I bought. I would by no means ever drive that fast with them. I limit the speed to 60 mph. Sometimes on downhills, I hit 65 mph, but I don't try to go faster as the wind resistance at higher speeds really kills the mileage.
Artypod View Drop Down
Direct Link To This Post Posted: 03 Feb 2017 at 2:39pm
My freeway time isnt that often, however they do say speed rating L (75mph). I assumed that meant good for 75?
Direct Link To This Post Posted: 02 Feb 2017 at 7:42pm
+1 on the Carlisle Load Range D tires. We did that because I did not like the wear pattern on our load range C tires. The load range D tires were a big improvement.
mcarter View Drop Down
Direct Link To This Post Posted: 02 Feb 2017 at 4:58pm
Hey Artypod,
Be careful with speed and your original tires the class c rated tires are a real concern over 60 or 65 MPH. I wouldn't recommend 75 but if you do so I would suggest you get a set of class D rated tires. I went with Carlisle's and I'm sure you can get other recommendations here on forum. Lucky is good but not better than smart. I have different issues with my tow vehicles but my Silverado 4WD has the least, it has the longest wheel base and highest capacity.
Direct Link To This Post Posted: 02 Feb 2017 at 4:29pm
I guess its better to be lucky than good.  I bought my 178 last spring and made half a dozen week long trips. I as well love my hometown water and cant stand most city water so have always carried a full tank.  Ive never had a problem with sway towing behind my f150 crewcab with no weight distribution hitch or sway bar.  Towed on freeways up to 75mph and up and down sierra nevada passes.
TheBum View Drop Down
Direct Link To This Post Posted: 16 Jan 2017 at 11:52am
We do a lot of boondocking in our 179 and it's not always convenient to fill up close to the destination, so we carry a full tank. We've never had excessive sway issues, likely for the reasons already stated.
Bboudens View Drop Down
Direct Link To This Post Posted: 14 Jan 2017 at 10:54am
Great to Know that bolting the tanks on is possible. No concern with voiding the warranty I bought the Pod "used" from a dealer and have only a dealers warranty and what they don't know won't hurt them. I'm more concerned about dropping my tank in the middle of nowhere than a warranty.  Part of the reason I went with an R-pod product was the torsion suspension and it's Boon-docking ability. This site has been great source of knowledge even tho my to do list of mods seems to get longer every time in sign in! I noticed that Pod People is the gent I've been looking for who reinforced his pod hitch. I'm planning on doing the same so it was nice to take a look at his mods. Thanks for all the info everyone!
Keep your stick on the ice
2016 178HRE
2011 Silverado 1500
Direct Link To This Post Posted: 14 Jan 2017 at 7:35am
Forum mates,
Good discussion. Going back to original post. The guy with the 177 was traveling home with a new to him RPod - no indication of sway control or WDS. He like me - with a new, empty RPod and a full fresh water tank, encountered sway. I absolutely agree, sway systems and proper loading, tongue weight, etc play in sway. The Interweb like the post has varying opinions of traveling with water in tanks and it's obvious there is no wrong or right. To me the learning experience was - don't pick up a RPod from a dealer that offers no clues, and tow it without the equipment to tow it safely, ignorance is not an excuse. I was guilty of that.
Direct Link To This Post Posted: 14 Jan 2017 at 7:16am
Bboudens,
Replace screws with bolts and lock nuts, I did on the one moveable brace for each tank, both sides. Some will say drilling into frame will void warranty. I used 1/4" hardened bolts thru frame. I couldn't find an easy way to strap, and that wouldn't have fixed the bracket to frame issues. There are several comparable sway bars out there, they all work basically the same. I would make sure you get a "kit" and make sure you get the bracket with small ball that mounts on the vehicle hitch. Some advertised they are sway for a WDS specifically, but they look the same to me. I buy from "etrailer" a lot because they are consistently lower in price than others.
Pod People View Drop Down
Direct Link To This Post Posted: 14 Jan 2017 at 6:39am
I think there are several factors that can induce sway.  Several posts have talked about water in the tanks.  while it is true that water sloshing around can contribute to sway, I think the main issue with water in the tank is the LOCATION of the tank.  Most of the pods have the fresh water tank behind the axle.  this loading creates less tongue weight.  It seems that by loading most of your cargo weight forward of the axle you are increasing the tongue weight.  Most people want to have a minimum of 10% tongue weight and it can go up to 12-15% depending on the TV and hitch set up. so, tongue weight is critical-not enough will definitely cause sway issues.
I try to always load with most of the weight forward of the axle AND use a good quality weight distribution hitch(Equalizer600#) with integrated sway control.  I can feel the difference in towing by moving some of our cargo back and forth in the floor as we travel.  Just moving one or two boxes back and forth can make a big difference. So, loading your trailer properly also is a critical component to eliminate sway. Again, keeping the weight forward increase tongue weight.
another important factor is good tires with stiff sidewalls that are properly inflated.
So, be careful how you load the trailer, carry a small amount of water when towing long distance and use a good WDH (properly adjusted)  with sway control and you will not have a sway issue in my experience. I have traveled cross country east to west and back several times and north to south and back several times with no sway issues.
Safe travels
Vann
Vann & Laura 2015 RPod 179
