  New Posts New Posts RSS Feed: Wiring Identification
Topic ClosedWiring Identification - Event Date: 31 Dec 2016
AmberKate View Drop Down
Direct Link To This Post Calendar Event: Wiring Identification
    Posted: 31 Dec 2016 at 12:17pm
Thanks to everyone!  Problem solved - you confirmed what was suspected & thanks for the shopping tips on meters but of course already had one.  You guys are the best!
Tootsie sends a special tail wag & New Year's greetings to everyone!  And my son is very glad to have this project completed!!!LOL
AmberKate & RIP Little Tootsie -
Direct Link To This Post Posted: 31 Dec 2016 at 11:12am
Ditto, the white should be the ground
Previously owner
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 31 Dec 2016 at 10:22am
You can pick up a quite adequate for the purpose multimeter at Walmart or someplace similar for about $10.
TT
FJ Cruiser
mcarter View Drop Down
Direct Link To This Post Posted: 31 Dec 2016 at 10:07am
+1 on continuity check. Just recently did some 12 volt wiring on my TT and ground wire was white. Plug into your TV and measure across marker light leads, when you have black on ground and red on 12v the meter should read +12. If it is backwards it will read -12. I'm taking for granted you have way to measure.
Oharley View Drop Down
Direct Link To This Post Posted: 31 Dec 2016 at 9:56am
The solid white wire should be ground but, you need to check it with a multi-meter for continuity to any convenient place on the frame that you can make good contact.
RP 179
2016 Ram 1500 5.7L Hemi 4x4
Direct Link To This Post Posted: 31 Dec 2016 at 9:47am
Help!!!
My flat tire that ripped off my fender still plagues me!  My son is here & we have a new fender on but are having trouble identifying the ground wire... white wire with green stripe?? white wire ???  etc.  Does anyone have an easy answer or the wiring schematic they could post?  As always thanks for your help
Amber & Tootsie
