  New Posts New Posts RSS Feed: Water flow problem
Topic ClosedWater flow problem - Event Date: 25 Jun 2016
mountainman View Drop Down
Direct Link To This Post Calendar Event: Water flow problem
    Posted: 25 Jun 2016 at 7:57pm
Has anybody experienced a water flow problem like I had this week? The first night of my trip with my two grandsons I washed the dinner dishes in the kitchen sink and both hot and cold water ran like they should. Three hours later when cleaning up for bed not a drop of water came out of either faucet. This was the case for the rest of the 5 day trip. The water at the bathroom sink worked fine for all five days. Don't use that sink however.
There may be a plug or kink somewhere but how do I locate it? Would using low air pressure to blow out the lines help? Take apart the kitchen faucet?
Mountainman
sailor323 View Drop Down
Direct Link To This Post Posted: 25 Jun 2016 at 8:06pm
Remove the aerator on the faucet and clean it out.  Easy fix.
Direct Link To This Post Posted: 25 Jun 2016 at 8:15pm
Ditto! clears it up 99% of the time!!
Direct Link To This Post Posted: 25 Jun 2016 at 8:17pm
If it's that easy to fix I feel really stupid. Have to wait till I go to the storage lot tomorrow to do this.
Thanks Sailor323!
Direct Link To This Post Posted: 25 Jun 2016 at 8:26pm
I clean mine out at the start of each season as part of de-winterizing.
Direct Link To This Post Posted: 25 Jun 2016 at 8:57pm
Thanks Sailor323!
No need to feel stupid, we've all been there
Direct Link To This Post Posted: 02 Jul 2016 at 11:34am
Water flow follow-up: Strainer had a small amount of sand in it along with 4! metal strainers. Put 2 back in. Then removed gooseneck and found a bunch of chips that looked like broken shells.   Cleaned that, hooked up hose, turned on water, and had plenty of water flow. Heading out again next week so will assume it's fixed.
mountainman
Westgl View Drop Down
Direct Link To This Post Posted: 02 Jul 2016 at 1:14pm
wow! ill have to look at that, good information
2010 RAV4 V6
2017 RPOD 179 Hood River Edition
Dual 6 volt Batts
Dual propane Tanks
Batt Disconnect
Bed leg extension
Dinette modification
Renogy 100w solar
Motorcycles several currently
