  New Posts New Posts RSS Feed: Power consumption of appliances
Topic ClosedPower consumption of appliances
Pod People View Drop Down
Direct Link To This Post Topic: Power consumption of appliances
    Posted: 20 Jun 2016 at 9:03pm
Vann & Laura 2015 RPod 179
Direct Link To This Post Posted: 20 Jun 2016 at 9:05pm
I have seen and used a chart that some one made that showed the power consumption of the refrigerator, heater, fan,  etc for the RPod. I have searched and can't find it. Can someone please point me in the right direction
Thank you
Vann
pnwcamper View Drop Down
Direct Link To This Post Posted: 21 Jun 2016 at 10:36am
Here you go
http://www.rpod-owners.com/forum_posts.asp?TID=1723&PID=14737&title=creating-an-instruction-maintanence-manual#14737
2014 R-Pod 177
2009 Toyota Tacoma Access Cab 4.0 V6
JandL View Drop Down
Direct Link To This Post Posted: 21 Jun 2016 at 12:20pm
This is the measurements I have made on my trailer. Your results may vary do to different manufactures. My microwave/oven is from Sunbeam and the television is a NAXA
AC & Fan start/run 23/16 amps
AC Fan only Hi 3.5 amps
Microwave 18/9.5 amps
Grill 8.75 amps
Convection oven 13 amps
Water Heater 11 amps
Refrigerator 1.2 amps
Battery Charger (max) 7.9 amps
TV 1.8 amps
JandL
2013 Honda Ridgeline
2012 177
2 Paynes in a Pod
Direct Link To This Post Posted: 21 Jun 2016 at 5:06pm
THANKS to both of you. that is very helpful.
Vann
Kantuckid View Drop Down
Direct Link To This Post Posted: 22 Jun 2016 at 9:50am
The previous owners of our Model 177/2016 said the jensen entertainment center will drain your battery when trailers sitting idle. I have a battery disconnect that takes care of that issue but would be even better were there a way to easily kill it dead when campers not being used.
WillThrill View Drop Down
Direct Link To This Post Posted: 22 Jun 2016 at 11:13pm
Truth be told, you shouldn't be leaving your Pod's battery just sitting out anyway, regardless of whether it's connected or not.  Lead acid batteries self-discharge, and they should be kept on a quality smart charger 24/7 when not in use on the Pod or else left connected and your Pod left plugged in to a power source when not in use.  This will greatly lengthen the lifespan of your battery.
2014 Hood River 177
2005 GMC Envoy XL
