Post Reply
| Author | |
2P$InAPod
Joined: 29 Mar 2015 Location: Massachusetts Online Status: Offline Posts: 15 |
Topic: ATF and PS Coolers for 2002 OdysseyPosted: 29 Mar 2015 at 10:54pm |
First, we are camping trailer newbies, need to get our 2002 Honda Odyssey ready to pickup the R-pod 179. We got the hitch, brake controller and 7-pole connector installed at U-Haul. Next will be the Automatic Transmission Fluid cooler and the Power Steering cooler (as suggested by Honda). We have the following questions if you can help - thanks in advance.
1. Do we need the PS cooler? 2. Should we consider an ATF and PS cooler combo unit (e.g., Derale D15902)? 3. Any suggestion on ATF and PS coolers manufacturer and model? 4. Honda parts more reliable? (they are certainly more expensive.) 5. Do we need to go to a Honda dealership to get it done? or a Meineke? 6. Anybody out there towing R-pod with an older Odyssey? anything we should be aware of? 7. <a non-cooler question> Do we need to beef up the rear suspension for our 2002 Honda Odyssey?
David and Kris
2015 RPod 179 2002 Honda Odyssey LX |
Joined: 29 Jul 2009 Location: MD Online Status: Offline Posts: 9065 |
Posted: 30 Mar 2015 at 1:57pm |
A power steering cooler is a maybe. I didn't need one for our Sienna. Derale is a known aftermarket cooler manufacturer, they make the transmission cooler I added to our Suburban. Check out etrailer for a good assortment of manufacturers and types. Read up on the types of coolers, see item 3 on this page. http://www.etrailer.com/faq-about-engine-transmission-coolers.aspx
Any mechanic should be able to install an aftermarket cooler. My local guy installed our tranny cooler and will soon install an oil cooler. All minivans are designed to carry people so they have soft rear suspensions. Forget air bags, stronger springs, etc. What you need is a weight distribution hitch (WDH). Search this forum for many discussions on that topic.
2P$InAPod
Posted: 31 Mar 2015 at 10:08pm |
Thanks techntrek.
We plan to have both ATF and PS coolers installed. Also got the Equalizer E2 6000. Hopefully my 2002 Odyssey is going to work out well... and last.
David and Kris
Post Reply
