Jannie
Topic: Newbie questions Posted: 20 Feb 2015 at 10:41pm |
When I pick up my new R-pod179 is it smart to add an extra propane tank and battery? I figure if I had an extra propane I could switch to the new one and get the old one filled. Oh yeah....where do you fill these puppies? Why aren't there gel batteries? Is there some reason? Is a second battery overkill? Anyone else have a Colorado and do I have to add a break thingy for the trailer? (sorry, don't know the terminology) It has some buttons factory installed: tow mode (you push this when towing and it charges the battery) and it has trailer sway control (TSC).
shroomer
Posted: 21 Feb 2015 at 1:18am |
Most users find that the propane lasts most of a season so having two tanks isn't essential. You can get them filled at a lot of places. A lot of rental companies and UHauls have tanks and will charge based on the gallons dispensed, not the size of the tank. The tanks that you swap out at a supermarket or drug store are an expensive way to buy propane.
A second battery is another story. Many of us use two batteries; some like two 6v batteries wired to give 12volts; others have two 12v batteries in parallel. I happen to have two gel batteries. Most seem to use the standard lead acid, which is fine. I use the gel because they go into my house as backup for my pellet stove in the winter and the gel batteries don't give off gases. I'm sure others will weigh in with more facts and opinions.
I'm not sure what you mean in your last section about a "break thingy". Your trailer dealer might be able to advise you.
Tars Tarkas
Posted: 21 Feb 2015 at 4:05am |
As for the propane, it's a matter of how you camp. Pods aren't really made for camping in below freezing weather because of the plumbing, but if you can get by without water, or even if you like early spring or late fall camping in the 30s & 40s, you can use a lot of propane. I used a tank in 4 days once dry camping when the temps were in the 20s. If you have electricity, a small electric heater is all you need though, and a lot cheaper since you're paying for the electricity anyway in the campground fee. The on-board propane furnace fan is LOUD too by the way.
A lot of the large campgrounds, especially the franchise ones sell propane. Farmers Coops, TSC, some country stores, will fill tanks. In some parts of the country at least, exchange tank sites are almost ubiquitous. You do pay a small premium to exchange tanks, maybe $5, and exchange tanks aren't as full as they could be, but sometimes that's the way to go. Depending on your tow vehicle and how you pack, you can carry a spare tank in the back of the truck -- it doesn't have to be mounted on the pod, although that is the most convenient. Some people carry 5 or 10 pound bottles a spares.
Whether you need two batteries depends on how you camp too. If you expect camp more than a couple of nights at a time without shore power, two batteries are probably a good idea. Get two of the same kind of batteries at the same time. Two 6v golf cart batteries will last the longest.
If "brake thingy" means brake controller, yes, it is an absolute requirement. It's probably the law in most states for trailers over a certain weight. More than that, it's a safety essential, and if nothing else it allows you to tow with a lot less stress. I did not have a brake controller when I picked up my pod and towed it 250 miles home. It is doable with extreme caution but it is not fun nor responsible. Compare it to driving on snow with 2WD and bald tires. Your Colorado must have a V6 so it will be quite adequate for towing the pod, but the pod will definitely push it around if you don't have a brake controller. It might already have one since it has a tow package, or it may just be wired so that one can be easily installed. And if you don't have one already, you will need a 7-pin connector on your truck for the trailer lights and brakes.
TT
FJ Cruiser
Podster
Posted: 21 Feb 2015 at 8:39am |
Hello from San Antonio and congratulations on your new 1 seven niner!
Shroomer and Tars Tarkas nailed it!
If you are going to camp without services (off the grid) for more than a couple days at a time then you may want some additional propane and 12v capacity.
If you are going to camp most of the time in parks with hookups available then you may not want to go to the expense to add the additional capacities.
Cliff & Raelynn
Ranger 4.0/178
Jannie
Posted: 21 Feb 2015 at 1:46pm |
TT
My manual says it has stabilatrac and alludes to a brake controller. I'm going to dealer Monday and ask if it has one. I'm assuming it is a thing I can push to activate it. I don't see that. I will get it tho. Thank you all for your wonderful information.
Jannie
Posted: 21 Feb 2015 at 1:49pm |
TT
My manual says it has stabilatrac and alludes to a brake controller.This truck came as tow ready and has all the hookups built in. I'm going to dealer Monday and ask if it has a built in brake controller. I'm assuming it is a thing I can push to activate it. I don't see that. I will get it tho. Thank you all for your wonderful information.
