  New Posts New Posts RSS Feed: install hot water switch inside a179
Topic Closedinstall hot water switch inside a179 - Event Date: 28 Aug 2014
collin62 View Drop Down
Direct Link To This Post Calendar Event: install hot water switch inside a179
    Posted: 28 Aug 2014 at 9:44pm
Great idea. Thanks guys.
Direct Link To This Post Posted: 28 Aug 2014 at 9:10pm
Ditto.  I was going to add an extra switch inside until someone posted about just using the breaker.
Goose View Drop Down
Direct Link To This Post Posted: 28 Aug 2014 at 2:31pm
We just use the breaker for the water heater switch, it is just easier like Charlie said. Heat the water during breakfast and turn it off when you are done eating and you have hot water all day. Goose
CharlieM View Drop Down
Direct Link To This Post Posted: 28 Aug 2014 at 12:37pm
Not having a 179 I can't address the location, but the Pod already has a separate circuit breaker for the WH in the power panel. Most people just leave the switch on the WH on and use the breaker as an on/off switch. If you do  add a separate switch, consider a lighted switch. Then you can see a a glance if it's on. The best place would be near the power panel so you can intercept the 120V AC line.
Direct Link To This Post Posted: 28 Aug 2014 at 12:13pm
Has anyone moved the hot water switch inside a 179? If so what location did you use, how did you route the wires?
