  New Posts New Posts RSS Feed: Safety Chains
Topic ClosedSafety Chains
cody91 View Drop Down
Direct Link To This Post Topic: Safety Chains
    Posted: 24 Mar 2014 at 3:39pm
It seems the safety chains on my trailer are hanging a little low when connected to my TV.  I'm concerned it may come in contact with the road and debris while traveling.
Has anyone ever tried to shorten the length of the safety chains?  Is it a good idea to do that?
Thanks
Cody
Boomertype View Drop Down
Direct Link To This Post Posted: 24 Mar 2014 at 3:49pm
As you make turns one side will get closer to the ground and the other side will raise.  You can use a simple device to keep them from dragging.  Here is an example.
http://www.fastwaytrailer.com/other/
Hairy Podders View Drop Down
Direct Link To This Post Posted: 24 Mar 2014 at 6:20pm
Just twist each chain until the length shortens up enough to prevent dragging. Do not twist the 2 chains together.
Darryl, Julie & Lindsey
2014 RP178
Direct Link To This Post Posted: 24 Mar 2014 at 6:46pm
Ditto.  However, DO cross the chains once so it will cradle the hitch if it falls.
Direct Link To This Post Posted: 24 Mar 2014 at 10:13pm
Thanks for the advice guys.  I'll give each of those a try.
Direct Link To This Post Posted: 25 Mar 2014 at 7:00am
+1, what Doug said....
2014 RP178
