| Author |
TRICERA-POD
Topic: Electrical Question in Campgrounds Posted: 13 Jun 2013 at 10:28am |
Tricera-Pod came with the standard electrical cord that is used to hook up during campground stays, 25ft. I was wondering if anyone knows what the standard amperage these electrical cords are rated for? 30amps, 50amps?
I know one has to have at least 30amps to run the A/C unit, but if there is only 50amps available at a campground does this mean I will burn out my cord and/or Pod is I use 50 amps to run my power?
Last year while tent camping in Keweenaw P. we were at a camp site with power. I had a extension cord that we used to power our computers. This was fine as we were not drawing allot of power to run a computer.
However, if we had our Pod then the electrical cord that came with the pod would have never reached the outlet, I needed at least 50ft to each the outlet.
With that being said, does anyone use an extension cord with the standard issue power cord that came with their pod? If so, should I get a heavy duty extension cord rated for 30 or 50 amps?
Electrical items always scare me a bit so I want to ensure I do not burn anything down when I hook up. I know a standard extension cord is not something one wants to use when powering the Pod in a campground. SO any advise would be great.
Carl & Sandee 2013 R 177 2012 Titan
Craneman
Posted: 13 Jun 2013 at 11:14am |
My 174 has a extension cord. Came with from previous owner. Check with your local rv, or boat stores Moe
Jo and Gary
2010 174
2011 Ford 150
TerryM
Posted: 13 Jun 2013 at 11:53am |
Your power cord is rated as 30amps. When you use an adapter to use a 50amp power post you are only tapping 30amps of the 50amps that are there. That is why you need the adapter. I always carry an extra 30amp cord and an extension cord for 15amp (regular 115v AC outlet).
Terry
Seanl
Posted: 13 Jun 2013 at 11:55am |
Electrical items always scare me a bit so I want to ensure I do not burn anything down when I hook up. I know a standard extension cord is not something one wants to use when powering the Pod in a campground. SO any advise would be great. |
Hi,
The cord that comes with the Pod is a 25 foot 30 amp cord. It will only plug into a 30 amp plug at the campground unless you have an adaptor. You can get a 15 amp adapter for the 30 amp plug that will allow you to plug the pod into a standard 15 amp household plug. When you do this you cannot run everything in the pod or it will blow a fuse or breaker. There are 50 amp plugs at some campgrounds for the big rigs but they have a different plug.
As for extention cords I have a 25 foot 30 amp extension cord that I use because campsites don't always put their plugs in the right place. You should not have any issue with a 25 foot extention. This is a link to a cord on amazon like the one that I have.
TRICERA-POD
Posted: 13 Jun 2013 at 12:04pm |
Now I see said the blind man. Thank you so very much. I did get the 15 amp adapter from my dealer so I am set there. I figured the 50 amp was for those big rigs. But better to ask those whom have gone before me to be safe
CharlieM
Posted: 13 Jun 2013 at 1:02pm |
One minor point. All that has been said is true, but with one additional thought. I have seen it reported that some of the campground 30 Amp connectors are worn out or non-functional whereas the 50 Amp connectors are working. Probably due to heavier use of the 30 Amp service. For those cases I carry a short 50 Amp to 30 Amp "Dog Bone" adapter. I've never used it but I love to solve problems before I have them. Quote the Boy Scouts.
TerryM
Posted: 13 Jun 2013 at 1:56pm |
I have 1 of those also and have used it. Terry
Thinker
Posted: 13 Jun 2013 at 2:59pm |
Please note and remember 30 Amp RV service is 110/120 Volt service. 50 amp RV service is 220 Volt service.
It is the nature of 220 that one hot leg plus the neutral will give 110/120.
Using a dog bone to convert 50A to 30A is only using half the power of the 50A connection.
I know, I know... too much information.
bhamster
Posted: 13 Jun 2013 at 4:39pm |
Originally posted by Thinker
Using a dog bone to convert 50A to 30A is only using half the power of the 50A connection. |
Everything you said is right, but I'm afraid some people will read "half the power of 50A" and think only 25A and therefore not enough for 30A service. This is not the case. The 50A service is really TWO 50A 110V lines (out of phase), so you could theoretically pull 100A at 110V if you used both legs. So pulling 30A from one leg at 110V is well below the 50A limit of each leg.
Thinker
Posted: 13 Jun 2013 at 5:07pm |
Everything you said is right, but I'm afraid some people will read "half the power of 50A" and think only 25A and therefore not enough for 30A service. This is not the case. The 50A service is really TWO 50A 110V lines (out of phase), so you could theoretically pull 100A at 110V if you used both legs. So pulling 30A from one leg at 110V is well below the 50A limit of each leg. |
Thanks for making that clear. I totally agree. The 50A is 50@220v.
or 100A@110v.
I should have said "only using less than half the available power from the 50A circuit"
