  New Posts New Posts RSS Feed: Pod Roof Material?
Topic ClosedPod Roof Material?
TIDALWAVE View Drop Down
Direct Link To This Post Topic: Pod Roof Material?
    Posted: 28 Nov 2012 at 10:50am
A forum member stated that the Pod roof is made of fiberglas. My Pod has a sticker which says that it is aluminum clad. Also, I installed a porthole in my door. I encountered a thin layer of aluminum, a layer of foam, and another thin layer of aluminum.
Are the doors constructed of a different sandwich of materials than the roof and walls?
TIDALWAVE
Keith-N-Dar View Drop Down
Direct Link To This Post Posted: 28 Nov 2012 at 11:35am
The R-Pod factory site specifies a "one piece seamless fiberglass roof."  And I know that is what mine is since I poked a hole in it the first time I backed it into a site.  Mine is a 2011.  It may have been otherwise at another time.
Keith-N-Dar
2011 R-Pod 177
2010 Ford F-150
Seanl View Drop Down
Direct Link To This Post Posted: 28 Nov 2012 at 11:43am
My wall out to in are layers of fiberglass, wood, foam, wood. I have not cut through the roof but I damaged it a little at the back when I tore off a stableizer (before I put the axle lifts on) and It was a fiberglass laminate on the outside.
Direct Link To This Post Posted: 28 Nov 2012 at 1:29pm
Here is the scoop. The walls are a layer of fibreglass 1/8" plywood, foam, 1/8" plywood. The door is a thin layer of fibreglass outside (no aluminum or plywood) foam and a layer of aluminum on the inside. The roof is one piece, Layer of fibreglass 1/8" plywood, the flat part of the roof is the same as the walls however the curved parts of the roof front and back has wood ribs in it and it is filled with fiberglass insolation. Test: Push with your thumb on the flat part of the roof, you'l find it is solid push the same in the curve and you find it is very flexible.
dsmiths View Drop Down
Direct Link To This Post Posted: 28 Nov 2012 at 8:09pm
Marwayne, good information on your post as usual, thanks.
Dane and Donna Smith
2011 RP-172
lift kit
