  New Posts New Posts RSS Feed: water hook up
Topic Closedwater hook up - Event Date: 16 Jul 2011
blissful View Drop Down
Direct Link To This Post Calendar Event: water hook up
    Posted: 15 Jul 2011 at 10:29am
On my 2nd camping trip I used a water filter and connected to fresh water.  When I disconnected it, my shower area was flooded with about 3" of clean water.  Is there something I should do to prevent this event?  Use the pump?hankful I discoveed it before going on the road.
Help!  BlissfulDeadDeadStar
secretbard View Drop Down
Direct Link To This Post Posted: 15 Jul 2011 at 11:11am
Was this clean water coming from the shower head?  How did that happen?
2010 Rpod 172   :)
2004 Chevy Trailblazer
Direct Link To This Post Posted: 15 Jul 2011 at 11:24pm
I'm not sure either.  Details?
TerryM View Drop Down
Direct Link To This Post Posted: 16 Jul 2011 at 3:51am
That is really strange.  It sounds like the gray tank was full or else it would have drained.  But I'll be darned if this makes any sense to me.
Terry
this_is_nascar View Drop Down
Direct Link To This Post Posted: 17 Jul 2011 at 10:00am
I don't understand what you're saying either.  If you've been setup and working like normal and at the end of the trip you have water in the bottom of the shower staw, it means you're grey tank is filled.
"Ray & Connie"
- 2017 R-Pod RP-180
Damour View Drop Down
Direct Link To This Post Posted: 17 Jul 2011 at 10:17am
It happens to me too. Water on the ground (exterior) under my shower after taking it ...
Still don't know why we will make some tests  .. and try to find the reason why ..
rp 171 , from Québec with not a good english writing lol
Direct Link To This Post Posted: 17 Jul 2011 at 6:44pm
So you see it draining out under the camper?  Sounds like a loose drain connection.  You could try opening the air vent under the shower door and looking in with a flashlight while the shower runs.
