  New Posts New Posts RSS Feed: Water pump issue
Water pump issue
Bonnieladd View Drop Down
Post Options Post Options   Quote Bonnieladd Quote  Post ReplyReply Direct Link To This Post Topic: Water pump issue
    Posted: 13 Jul 2026 at 9:23pm
At the start of this season, the original water pump on my 2022 RPod 193 started making a loud sound when turned on and the faucets spit air and a little water. The sound is similar to the sound a kitchen sink makes when the dishwasher is draining - but louder and consistent. The fresh water tank is full.
1) is this just the case that the pump needs replacing?
2) is it relatively easy to replace?
I’m pretty handy when it come to DIY, just have never worked on the RV.
Thanks
Danny
2022 RPod193
Music City USA
gpokluda View Drop Down
Post Options Post Options   Quote gpokluda Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2026 at 7:01am
That looks like a different pump than what I had in my Rpod, but they all work on the same premise. Start by checking all connections are tight and not leaking air. Then the filter screen usually under a clear plastic dome. you can also prime it here by pouring some water in then sealing it up. Finally, if all else fails, the check valve may be stuck or not working properly.
Google the brand of pump you have and you should find some trouble shooting guidance.
Gpokluda
2017 Rpod 179(sold 2023)
2022 Escape 5.0TA
2022 Ford F150 4X4 3.5EB
Honda SCL500
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2026 at 10:02am
I can't really see through that tangle of lines, but make sure there are no kinks. Also, as suggested above, check the filter screen. Also, check that the valve for the antifreeze hose is not partially open and that all fittings are tight.
Edited by StephenH - 20 Jul 2026 at 10:34am
Post Options Post Options   Quote Bonnieladd Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2026 at 1:09pm
Thanks all.  When I got the pump off, I could see that the housing for the filter was cracked and when I moved it the top just popped off completely.  I replaced the filter part and we are back in business.
I appreciate this forum!
2022 RPod193
Music City USA
