  New Posts New Posts RSS Feed: Fresh water tank issue
LeonMBarnes View Drop Down
Post Options Post Options   Quote LeonMBarnes Quote  Post ReplyReply Direct Link To This Post Topic: Fresh water tank issue
    Posted: 29 Mar 2026 at 6:21pm
Strange, when connected to city water the fresh water tank fills up and overflows. This started after we added 15 gallons to the fresh water tank, and went boondocking using the water pump for the first time since buying this pre-owned RPod. For now we turn on city water, wait for the fresh water tank to overflow, turn city water off and water pump.
Has anyone encountered this and/or has wisdom to share.
Scratching my head…
Leon and Johanne Barnes
Adventures in Retirement
Beckman0208 View Drop Down
Post Options Post Options   Quote Beckman0208 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2026 at 6:47am
Check valve failure in pump. Replace the pump or add a check valve on incoming side of the pump
JR View Drop Down
Post Options Post Options   Quote JR Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2026 at 12:52pm
While connected to city water and you notice the fresh water tank filling up. Shut off the city water then cycle the fresh water pump several times and normally that allows the check valve in the fresh water pump to reseat itself and then it will work correctly for a while. Meaning that it will stop the flow from the city water flow to the fresh water tank.  If the problem persist you can or have a tech remove the pump and clean out the check valve, or you may elect to replace the water pump. Hope this helps Jay
Jay
179/2019
