MMOexp WoW Classic 20th Anniversary: Stance Manage |
Post Reply
| Author | |
Stellaol
Post Options
Quote Reply
Topic: MMOexp WoW Classic 20th Anniversary: Stance ManagePosted: Today at 10:13pm |
You're timing your movement around your swing timer, which means the enemy attacks less often while you lose no damage output. Since mobs attack faster than you do, standing still results in WoW Classic 20th Anniversary Gold significantly more damage taken. While kiting in and out, you can: Apply Rend Queue Heroic Strike Fish for dodges to trigger Overpower Rend is especially valuable early on. Even though it's not rage-efficient, it continues dealing damage while you're kiting, and if Rend is dodged, it procs Overpower—one of your highest-damage abilities for only 5 rage. Once you unlock Intercept at level 30, hamstring kiting becomes even better. When enemies reach low health, you can switch to Berserker Stance, Intercept for a stun, and finish them with an auto attack or Execute. This is also exactly how Warriors PvP against other melee classes. Stance Management and Macros Warrior stance swapping is powerful but clunky without macros. Many players struggle simply because they manually switch stances and lose rage. The solution: stance macros. Every ability that requires a specific stance should automatically switch you into that stance when pressed. This lets you focus on gameplay instead of micromanaging your UI. For interrupting casters, Shield Bash macros should automatically equip a one-hander and shield, bash, then allow you to swap back to your two-hander afterward. If your action bars are laid out consistently across all stances, you'll never need to manually switch stances during combat. Weapon Progression While Leveling Weapon upgrades are everything for a Warrior. Always prioritize top-end damage, especially for two-handed weapons. Key early upgrades: Crescent Staff (Wailing Caverns quest) - your first major power spike Blackfathom Deeps two-handed sword Corpsemaker (Razorfen Kraul) - strong mid-level weapon Whirlwind Axe - mandatory and game-changing The Whirlwind Axe quest becomes available at level 30, but realistically, you'll complete it around 34-40 unless you get help. Buying quest materials from the auction house can save enormous time. Whirlwind Axe can easily carry you into the late 40s. After that, dungeon upgrades like Gatorbite Axe from Maraudon or high-quality blues and epics may replace it. Despite focusing on two-handers, Warriors should always keep a shield and a one-hander available for tanking dungeons. Any Warrior can tank low-level content—learning to tank makes grouping faster and smoother for buy WoW Classic 20th Anniversary Gold everyone.
Post Reply
