Attaching steps |
Post Reply
| Author | |
Ciberpine
Joined: 21 May 2021 Location: Lewisville, Tx Online Status: Offline Posts: 23 |
Post Options
Quote Reply
Topic: Attaching stepsPosted: 10 Jan 2026 at 6:52pm |
Model 190. The steps have pulled loose from the attachment point. I am surprised that only one bolt holds the step bracket and it was attached to the flooring, not the frame. The bolt has a small square head and it has pulled through the flooring. The step bracket has a flange that goes under the square tubing frame, but there is no bolt there on either left or right side bracket. Any suggestions on reattaching the steps? ![]() ![]() |
Scott and Noreen
2017 R-Pod 190, 2011 Toyota Tundra Pilgrims on the way to the Celestial City |
gpokluda
Joined: 11 Nov 2018 Location: East Idaho Online Status: Offline Posts: 504 |
Post Options
Quote Reply
Posted: 11 Jan 2026 at 7:31am |
Wow. Looks to me you have a couple of options. The best, most costly and inconvenient is to take it to a welding shop and have the steps welded to the frame. The easiest would be to through bolt it from the inside of the camper. You would have an exposed bolt head but since it is so close to the door, it shouldn't be too big a deal. Just use some sealant on the bolt to seal the intrusion and use some sort of back plate like a fender washer on the inside.
Just an observation, that bolt looks rusted all the way to the head. Wondering if you had some water intrusion that weakened the floor decking.
Gpokluda
2017 Rpod 179(sold 2023) 2022 Escape 5.0TA 2022 Ford F150 4X4 3.5EB Honda SCL500 |
JR
Joined: 31 Aug 2018 Location: Manistee, MI Online Status: Offline Posts: 408 |
Post Options
Quote Reply
Posted: 11 Jan 2026 at 8:50am |
+gpokluda / I caught mine before the bolt pulled through the flooring. I have a 2019 and they used elevator bolts through the flooring. Those have really flat heads and the heads are maybe 1" in diameter. I installed really block of hard plastic instead of the flooring where the bolt goes through the flooring. On both sides which spreads out the load. Also where the steps attach to the frame they used self tapping metal bolts. I replaced the original ones with larger diameter self tapping metal bolts. Seems to be holding. Hope this helps.
Jay
179/2019 |
Ciberpine
Post Options
Quote Reply
Posted: 12 Jan 2026 at 11:15am |
gpokluda and JR, Thank you both for your help. |
Scott and Noreen
Post Options
Quote Reply
Posted: 12 Jan 2026 at 12:25pm |
I would also bolt that flange to the frame. I would not trust just two bolts through the floor.
jhlee730
Joined: 19 Jun 2026 Online Status: Offline Posts: 1 |
Post Options
Quote Reply
Posted: 19 Jun 2026 at 10:30pm |
I have those steps on my rpod as well. however my issue is not the bolt falling thru. my issue is the bracket breaking at the bolt underneath. I was wondering if you had found a replacement step that had the one bolt on each side and the screw that attached the steps to the frame underneath I can't find who even made these manual steps. doesnt appear to be lipert.
thanks jim |
Post Reply
