Wall / Floor Joint |
Post Reply
| Author | |
hank1212
Joined: 17 Jun 2022 Location: WV Online Status: Offline Posts: 2 |
Post Options
Quote Reply
Topic: Wall / Floor JointPosted: 09 Jan 2026 at 9:32pm |
I have a 2018 R-POD 189 that has had the floor replaced by local shop once and is now rotted again. It appears that shop did not fix the leaks. My plan now is to replace the floor with aluminum diamond plate and use a carpet over that. My
question(s) has anyone seen how the walls attach to the frame? The few
dated (low res) pictures that I have seen online appear to show the
walls sitting on the floor wood vice the perimeter metal frame. If any
one has pictures of this connection and how the walls are bonded to the
frame it would be appreciated. Thank you, Hank
gpokluda
Joined: 11 Nov 2018 Location: East Idaho Online Status: Offline Posts: 496 |
Post Options
Quote Reply
Posted: 10 Jan 2026 at 7:43am |
Hank, I can't help you with how the mechanical joint is established, however I would like to bring something to your attention. The 189 probably has the same weight challenges my 179 had which is it has a 3500lb axle which will limit the over all weight of the camper. My guess is in order to achieve enough rigidity in the floor, the diamond plate is going to have to be thick which may make it heavier than the plywood and thus cut into your weight capacity. Not sure, but just keep in in mind. Good luck.
Gpokluda
2017 Rpod 179(sold 2023) 2022 Escape 5.0TA 2022 Ford F150 4X4 3.5EB Honda SCL500 |
GlueGuy
Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2780 |
Post Options
Quote Reply
Posted: 10 Jan 2026 at 12:06pm |
+1
If you add that much weight, you will probably have to do something about the axle.
Post Reply
