  New Posts New Posts RSS Feed: Opening 203
Opening 203
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Topic: Opening 203
    Posted: 26 May 2025 at 6:08pm
You got it.  The only possible issue you may have is when you charge up and run the water pump, you may have lousy pressure or a lot of air in the lines, which is caused by the valve upstream of the 3 way pigtail (upstream of the water pump) not being totally shut.
Ryan-203 View Drop Down
Post Options Post Options   Quote Ryan-203 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2025 at 12:40pm
Good day,
This is my first R-Pod but I have owned trailers in the past which I winterized and opened for the season.
Could someone let me know if I’m missing something?
Open hot water tank bypass and flush lines. Easy, right? Is there anything else with the pump?
Thanks,
