gfi will not reset |
Post Reply
| Author | |
Rollerman
Joined: 24 Oct 2024 Online Status: Offline Posts: 1 |
Post Options
Quote Reply
Topic: gfi will not resetPosted: 24 Oct 2024 at 1:58pm |
reset gfi but will not stay in, replaced gfi recepticle, replaced circuit breaker, have power at the breaker, no power at the line connection on the gfi outlet.
location of power inverter on 2020 Rpod R179? Is there a gfi on the power inverter? Any suggestions please?
GlueGuy
Joined: 15 May 2017 Location: N. California Online Status: Offline Posts: 2792 |
Post Options
Quote Reply
Posted: 25 Oct 2024 at 10:13am |
It sounds like you have a ground fault somewhere downstream of the GFI. I suggest you disconnect the protected hot leg to verify that is the case. If the GFI stays reset, then it will be a process of elimination.
There aren't that many devices connected to 110 in an Rpod. |
Post Reply
