Furnace making "crackling" sound (and other stuff) |
Post Reply
| Author | |
Sierra Nomad
Joined: 12 Jun 2024 Online Status: Offline Posts: 1 |
Post Options
Quote Reply
Topic: Furnace making "crackling" sound (and other stuff)Posted: 19 Aug 2024 at 2:59pm |
For some time, the furnace in my R-Pod 178 has periodically been making a weird crackling noise. It sounds like bacon frying. Recently these have become longer in duration. It happens every few weeks Has anyone experienced this? I haven't used it in a long time.
Also, gas stovetop inside does not work, although the outside one does. I heard I should maybe clean the lines? Any info on how to do that? Thank you!
Joined: 23 Feb 2012 Location: Kewadin, MI Online Status: Offline Posts: 3436 |
Post Options
Quote Reply
Posted: 22 Aug 2024 at 4:21am |
I have an older 2011 177 which has been in my possession since March 2011. Yes, this is a sound that is heard every now and then, probably due to the metal expanding/contracting when heating and cooling and lasts for maybe 15 seconds or so. How long has it been since being used and do you hear this when using both electric and propane or only one of those? If one stove works and the other doesn't it likely points to a pinched gas line. I believe the 178 stovetop is located in the slide portion. Try lighting it when the slide is closed vs. open. If it lights one way but not the other it is definitely a pinched line and should be relatively easy to find. IMHO this is the likely scenario since the outside stove lights. Do you hear or can you smell the propane when attempting to light the inside stove? If not, then you line is pinched or you have a lot of crud built up inside each burner, with the latter being quite unlikely. However, if inside stove doesn't light and you can smell gas, (when slide is in or out) then remove the line going from your propane regulator to the front of your 178. If a black gooey substance drips out - that is where the problem lies. Clean out that line and if bad get underneath and follow the propane line to the stove inside and open that line as well. Hopefully you or someone you know has a compressor - blow the line out from the stove to the front of the pod and you should be good. How is everything else working as this will also let you know if the dreaded black goo is in the lines or not. Does the HW tank fire up and give a nice blue flame when heating? Also look for a healthy blue flame in the combustion area at the rear of the fridge when running on propane. If the lines had goo in them and have been cleaned out and the flames are yellowish when burning you will likely need to replace the regulator as well, which usually runs around $ 20 - $ 25.
gpokluda
Joined: 11 Nov 2018 Location: East Idaho Online Status: Offline Posts: 496 |
Post Options
Quote Reply
Posted: 22 Aug 2024 at 8:11am |
Ours would do this occasionally as well. Never tracked it down because it was sporadic and didn't seem to affect anything. Now if it smelled like bacon frying, that would be a different story...
Gpokluda
2017 Rpod 179(sold 2023) 2022 Escape 5.0TA 2022 Ford F150 4X4 3.5EB Honda SCL500 |
Post Reply
