  New Posts New Posts RSS Feed: Attaching to shower surround
vmh View Drop Down
Post Options Post Options   Quote vmh Quote  Post ReplyReply Direct Link To This Post Topic: Attaching to shower surround
    Posted: 02 May 2022 at 6:49am
Thanks for the tips. I figured we'd have to get some type of sealant anyway. Though we'll have to wait since the R-Pod needs to go back to the dealer. Bathroom door fell off its track, rain showed a leak by the driver's side front window, and a few other minor things. Good thing we set it up in the driveway and there was a rain storm
2022 R-Pod195
Towed by 2022 Ford Ranger
Post Options Post Options   Quote StephenH Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2022 at 7:28am
Instead of Command Strips, you may wish to try something thicker like the double-sided foam strips. They should conform to the texture easier. Barring that, perhaps a bit of clear Lexel sealant will work. These will be more permanent than Command strips.
Also, welcome and congratulations on your RPod 195. We have a 2016 RPod 179 that we have traveled thousands of miles with and have enjoyed it very much. I hope you get much enjoyment from your adventures with your RPod and make many great memories.
vmh View Drop Down
Post Options Post Options   Quote vmh Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2022 at 6:54am
I have attempted to attach various Command Strips as well as suction cups to the shower surround in the R-Pod 195 to no avail. I prepped the surface by washing and wiping down with alcohol but nothing sticks, not even a little bit. I had wanted to put up a few hooks and use a suction cup soap dish in the corner. It seems as if the surface is just too textured.
Any suggestions?
Thanks.
2022 R-Pod195
