  New Posts New Posts RSS Feed: Seat cushion woes
Seat cushion woes
Jenga Jack View Drop Down
Post Options Post Options   Quote Jenga Jack Quote  Post ReplyReply Direct Link To This Post Topic: Seat cushion woes
    Posted: 04 Nov 2021 at 10:51am
The ā€œLā€ shape support arm for the seat cushions is coming apart on our 2014 R-Pod 178. The horizontal piece is bending and cracking, and on the vertical section the screws have ripped out and are cutting the back of the seat cushion. Has anyone experienced this and/or have a solution?
2014 R-Pod 178 aka the "Kobra Pod"
following a 2015 4Runner wherever it may wander
Rosie View Drop Down
Post Options Post Options   Quote Rosie Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2021 at 10:55pm
We removed ours after the first season to convert to a bed. They had pulled out of the wall soon after we bought our pod.   Repaired the holes in the wall with some patch stuff I had left over from a boat repair.  In my mind they are really just cosmetic.  They were in the way when sitting on the end of the bench.
Post Options Post Options   Quote jato Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2021 at 6:56am
Although we haven't experienced this on our 2011 177 I have seen mods where the owner took a piece of 1/2" plywood and cut it out to the same shape, sanded then coated it with either polyurethane or a color of their choice and re-installed.  Looked great and solved the problem.
