Post Reply
| Author | |
106G
Joined: 11 May 2021 Location: HOFFMAN ESTATES Online Status: Offline Posts: 36 |
Topic: Soft Floor - RPod 171Posted: 27 Jul 2021 at 5:44pm |
The floor on my 171 is quite spongy in the area in front of bathroom / sink area. I assume there was a leak at some point & the foam in the floor broke down or got saturated. How concerned should I be? Will it just stay this way, or will it get to a point where the floor falls apart? Any suggestions on a mitigation for this issue?
Thanks, Jack 2010 RPod 171 |
mjlrpod
Joined: 27 Sep 2016 Location: Massachusetts Online Status: Offline Posts: 1221 |
Posted: 27 Jul 2021 at 6:00pm |
It's a problem, and yes, water is probably the culprit. You must be sure the leak has stopped before moving on. You may need to cut out the bad section, and try to replace it.
2017.5 Rp-172
Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6483 |
First off, see if it is caused by a leak and address that. That is urgent.
Then, you could see about reinforcing the floor. If there is not a cross-brace in that area, you could consider having one fabricated and installing it. See my mods or search for floor brace. You may need to use the advanced search function and expand the date range to allow for seeing older posts. The default is six months or newer.
106G
Posted: 27 Jul 2021 at 7:35pm |
Thanks.
Post Reply
