  New Posts New Posts RSS Feed: towing advice -- are we crazy?
Topic Closedtowing advice -- are we crazy?
dsj123 View Drop Down
Direct Link To This Post Topic: towing advice -- are we crazy?
    Posted: 09 Feb 2021 at 1:06pm
All --
We're aiming to buy a R-Pod 192 which grosses 4900 lbs. We are also planning on getting a '18 Highlander with a 5000 lb towing capacity.
Although we're (nearly) flatlanders here in Minnesota, we've heard stories about engines being overworked due to the wind resistance of an RV trailer, and we do plan to eventually do some camping in more mountainous areas.
Are we crazy? Looking for your wisdom; thanks much!
David & Barb
Twin Cities
Pod_Geek View Drop Down
Direct Link To This Post Posted: 09 Feb 2021 at 1:21pm
You mean a 202?
2020.5 R-Pod 195 Hood River
2018 RAM 2500 6.4L
podwerkz View Drop Down
Direct Link To This Post Posted: 09 Feb 2021 at 2:19pm
Again, use the 80% rule:
5000 pound towing capacity means look for a trailer UNDER 4000 pounds GVW (80% of 5000)
This will help keep you safe and secure as you tow.
Direct Link To This Post Posted: 09 Feb 2021 at 2:44pm
Nope -- the weird singular one with the murphy bed!
Direct Link To This Post Posted: 09 Feb 2021 at 2:46pm
Thanks much. However, in order not to have to buy a moose of a vehicle to tow more (our biggest current vehicle is an Outback:), we were thinking of going without water in the tanks to get it closer to net weight, 3,449 lbs. Is that doable?
David
Colt View Drop Down
Direct Link To This Post Posted: 09 Feb 2021 at 3:13pm
You need to weigh, or have the particular trailer weighed.
There is no reason at all you can't tow well under the max gross weight.
The UVW for my 180 is pretty close, yours likely is, too.  But then, I added another ~175 lbs of "stuff" even trying to be careful of adding weight.
Aero drag is controlled with speed.  Prolly no reason to tow over 60 MPH.  My OEM tires had a 65 MPH speed rating.
John
'16 R-Pod 180
mjlrpod View Drop Down
Direct Link To This Post Posted: 09 Feb 2021 at 3:31pm
I have a 195, I think the 192 is slightly heavier than the 195. I tow with a frontier rated at 6100 - 6300 pounds. I would tow a 192 with my truck, but I know it would be just enough truck to do the job. I don't really think your 5,000 pound capacity is up to the job.
2017.5 Rp-172
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
mcarter View Drop Down
Direct Link To This Post Posted: 09 Feb 2021 at 3:34pm
You're not crazy, but personally you're taking some chances that could be life changing. A 5000 lb vehicle is not adequate for a 4900 lb tow.
Direct Link To This Post Posted: 09 Feb 2021 at 3:36pm
Thanks very much, all -- sounds like we should start shopping for a bigger vehicle!
David
Direct Link To This Post Posted: 09 Feb 2021 at 3:38pm
The amount of drag you are pulling is greatly increased as your speed increases.  Think of it as a huge sail or parachute that is dragging you down and making your engine work that much harder as you travel down the road.  Have to agree with mjlrpod above.  Now if you just plan to stay around home in Minnesota and Wisconsin and not travel too far, you can probably do it but for longer hauls and highway speeds, personally I would look for a 'stouter' TV with more towing capacity.
