  New Posts New Posts RSS Feed: Microwave Stopped Working
Topic ClosedMicrowave Stopped Working
MikeP View Drop Down
Direct Link To This Post Topic: Microwave Stopped Working
    Posted: 08 Sep 2020 at 9:38am
Hi folks. Fairly certain my next action is to get it serviced, but figured I'd run it by the fine folks here.  I wasn't there when it happened but apparently it went down like this.  Highpoint microwave. Wifey just finished cooking on convection at around 400; very shortly after put a microwave safe plate in to reheat something and around 15 seconds in she heard a loud-ish pop and it stopped working. No power; no blown fuse; no issues with any other electronics, etc. We were running on campground power and no issues there.  Any suggestions are appreciated.  thanks
MP2112
Direct Link To This Post Posted: 08 Sep 2020 at 10:17am
I assume by no blown fuse you mean all your circuit breakers are on? Sometimes its hard to see that so you might try resetting them (off then back on). If not then see if you can find where the microwave is plugged in. Unplug it then check that that outlet works running something else. Then plug the micro back in and try it again.
If none of that works you will have to pull out the microwave or have someone do that for you. I don't think anyone will service it, just replace it so you could do that yourself if you wanted.
mjlrpod View Drop Down
Direct Link To This Post Posted: 08 Sep 2020 at 11:48am
I've heard complaints about the highpoint micro before. Could be a bad one.
2017.5 Rp-172
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
