  New Posts New Posts RSS Feed: Different-sized tires
Topic ClosedDifferent-sized tires
poston View Drop Down
Direct Link To This Post Topic: Different-sized tires
    Posted: 25 Sep 2018 at 2:24am
Just wondering whether it would be a problem using a smaller/bigger diameter tire as a spare?
I bought some 15" tires from Kris B, but only bought two rims.  Didn't think about the spare.  I could get a cheapo 15" rim for the spare.
But what if I used one of my 14's as a spare to drive on in an emergency until I could get the flat 15" repaired?  The 15's are about 2.8" taller.
All my vehicles are 4WD or AWD, so I can't do that on my cars, but what about on the trailer where both hubs are independent?
Jim
Virginia City, Nevada
2016 R-pod 180
2023 R-pod 153 BEAST MODE!
2015 Nissan Xterra
mcarter View Drop Down
Direct Link To This Post Posted: 25 Sep 2018 at 8:26am
Small diameter spares are the norm in the auto industry, you could travel a short distance with 2 different diameter tires on a trailer. I wouldn't recommend it for the full trip.
GlueGuy View Drop Down
Direct Link To This Post Posted: 25 Sep 2018 at 8:46am
I think for emergency use, you would probably be OK. If there was a differential involved, it would be a most definite no-no. Be aware that the different sizes will be rotating at significantly different RPMs, and that there would be a slight list to starboard (or port) with the trailer. Like Mike says, it would not be for an actual trip.
Direct Link To This Post Posted: 26 Sep 2018 at 8:55pm
Thanks gents!  Your advice seems totally solid, maybe because that's what I was thinking too!
And I calculated the slope to the side of the shorter tire at about 1.5%, which is less than the typical crown on a paved road.
I think I'll carry my smaller spare until I find a good deal on a larger rim. And I hope I don't have to test my rationalizing.
Jim
2016 R-pod 180
2015 Nissan Xterra
