  New Posts New Posts RSS Feed: Trial trip rp179
Topic ClosedTrial trip rp179
NAP1947 View Drop Down
Direct Link To This Post Topic: Trial trip rp179
    Posted: 03 Jun 2018 at 6:58pm
We finally got out in our new pod, took 3 days from Ottawa to Ferris PP near Campbellford, ON.
Great park, site with a beautiful view, mix of 4 lane and 2 lane road, Venza  and 179 are a good pair.
Leaving the car in straight “D” the revs never got above 4000 on steep hills and most of the time was at less than 2500.  Averaged 15L/100 Kim’s (14.7 miles/US gallon).  Not happy with 200+ transmission temp but will have that looked at.
Now to the learning part, when hooking up in +30F temp with only a 15 amp connection I must put the water heater on propane not 110 or the AC will not run, first night very hot until operator got this figured out, may never put the water on 110 again.  Also, change fridge from battery to 110, as the fan in the converter drove Susan crazy all night.  Due to the heat we used a lot more water than anticipated, started with about 2/3 tank and just barely had enough for coffee on the last morning.
Now we will start making the 179 our own, we have a list of mods to make, the first being a short ladder or stool, what do other folks use, I figure 3 steps to be about right but what I have seen don’t carry my weight.
In short we had a great time and are planning the next trip.
Cheers.  Big smileBig smileBig smile
Susan and Norm
2016 Venza, V6 factory tow
2018 RP179
Kup-Pod View Drop Down
Direct Link To This Post Posted: 03 Jun 2018 at 7:35pm
Hello fellow Ontarioan!
Ferris is an old haunt for me for camping back in our earlier days.  Charleston Lake is also a great option in that area - one of our favorites.
Your comments on fuel economy sounds about right... I tow my 178 with a Santa Fe V6 along the same kind of terrain and typically get 14-15 l/100km.  The wind resistance is the major issue.  I'm thinking about getting one of those air deflector thingies to put on the roof rack of the Santa Fe.
A Venza seems a bit underpowered for it, but I don't know what the rating is for a Venza with a V6.
As far as power useage goes, I know the Provincial Parks are pretty good, but the power outlets are typically too far away.  If you're working off the 110 / 15 amp portion and using the adaptor to use a long extension cord , that might be part of your problem.  I went out and invested in a couple of 25ft heavy duty cords so I could stick with the 30Amp outlets.
Finally, I typically switch the fridge over to propane since it seems to be the most efficient way to use the 3-way fridges.
Its all trial and error though.  Enjoy the process!
2017 RP-178
2021 F150 5.0l
"Lead me on a level path"
Direct Link To This Post Posted: 03 Jun 2018 at 7:39pm
Congrats!!
Previously owner
Direct Link To This Post Posted: 04 Jun 2018 at 7:18am
Appreciate the comments.  You are correct about connecting the 110 with a 25’ 20 amp extension cord, I decided to use an existing cord to figure out what I need, could not decide whether to get a 25 or 50’ 30 amp cord.  I will get one 25’ for now and another if we need it, not inexpensive.  We have been to Charleston Lake with our tent trailer and it is a great location, another great one is Bon Echo.
Susan and Norm
2018 RP179
Direct Link To This Post Posted: 04 Jun 2018 at 9:33pm
NAP1947,
As new owners, it came to my mind when talking about extension cords, that you should really ensure you have a good ground connection.  see discussion http://www.rpod-owners.com/forum_posts.asp?TID=4748
I found out about this through this forum, and am glad I did.  I had it twice already where my trailer was "hot" because of a faulty connection.  Worth checking out!
2017 RP-178
2021 F150 5.0l
PilotPodder View Drop Down
Direct Link To This Post Posted: 05 Jun 2018 at 6:12pm
Congrats on your maiden voyage from a fellow happy 179er! ~PP
