  New Posts New Posts RSS Feed: Electrical taillight problem
Topic ClosedElectrical taillight problem
rawest50 View Drop Down
Direct Link To This Post Topic: Electrical taillight problem
    Posted: 25 Jun 2017 at 5:42pm
I noticed last night my right RPod led taillight was on but very dim. The Pod is parked in my driveway and connected electrically to my house power. Nothing hooked to my 7 point trailer connection. When I shut off the power from the house the light went out. What is going on?
2017.5 RPod 179
2017 Jeep Unlimited Wrangler
2 Weiner dogs
Great wife puts up with my BS
❤️ Thoroughbred Racing.
Direct Link To This Post Posted: 25 Jun 2017 at 9:18pm
Wire going to light has a nick in the insulation where it crosses another 12V line that has power being supplied by the converter? Polarity problem? I take it this does not happen when the battery/batteries are supplying power but only when the R-Pod is plugged in and presumably, the converter is supplying 12V power?
Edit:
What is more worrying is if there is a piece of 120V wiring that is leaking current to the frame. This is going to be something you will want to get checked out. Please make an appointment with your dealer to get this checked.
Direct Link To This Post Posted: 26 Jun 2017 at 8:53am
Thanks.
2017.5 RPod 179
2 Weiner dogs
Direct Link To This Post Posted: 26 Jun 2017 at 12:51pm
Is there anyway I can check this?
2017.5 RPod 179
2 Weiner dogs
GlueGuy View Drop Down
Online Status: Online
Direct Link To This Post Posted: 26 Jun 2017 at 12:58pm
A DVM is your friend. I would check the voltage going to your taillight to see what kind of voltage is getting there (e.g. 12VDC or something else). Troubleshoot from there.
Direct Link To This Post Posted: 09 Jul 2017 at 4:25pm
Originally posted by StephenH
Wire going to light has a nick in the insulation where it crosses another 12V line that has power being supplied by the converter? Polarity problem? I take it this does not happen when the battery/batteries are supplying power but only when the R-Pod is plugged in and presumably, the converter is supplying 12V power?Edit:What is more worrying is if there is a piece of 120V wiring that is leaking current to the frame. This is going to be something you will want to get checked out. Please make an appointment with your dealer to get this checked.
I called my dealer. Weeks before they can look at it. We have a week long trip next weeks and have already spent a lot of money for sites and events in the area. Anything I can do? How big a problem is it? I am not electrically inclined so I am clueless.
2017.5 RPod 179
2 Weiner dogs
Direct Link To This Post Posted: 09 Jul 2017 at 4:52pm
One thing to check.. look at the 7 way, make sure it is clean and dry, they get wet, can short a bit.. cause issues. The running light circuit is right next to the 12v hot..
Direct Link To This Post Posted: 10 Jul 2017 at 7:27pm
I checked my 7 point connection on my trailer. Wow. It was wet and copper corrosion was present. Had a cover cap on on it but I noticed the groove was not aligned with the connector. Left a gap for water to enter. With the rain we had it probably funneled water into the connection. He is my question. Pod connected to house power and battery at full charge, what you mentioned could cause my tail light to glow?
2017.5 RPod 179
2 Weiner dogs
Direct Link To This Post Posted: 10 Jul 2017 at 7:49pm
Possibly. Both the 12V "power", as well as tail light connectors are in there. If there is a bridge of some kind between them, then just plain power could light the lights.
See if you can clean it out, then squirt in some DC4 or similar dielectric goo. The DC4 is hydro-phobic, and is used in a lot of applications where you don't water to get in. It's also non-conductive.
Direct Link To This Post Posted: 12 Jul 2017 at 10:19am
I ordered the DC 4. I am a little confused. If it is non-conductive will it not interfere with the 7 point connection of the vehicle to R Pod connection? Coat the connectors? It looks like a great product since it is used in the aircraft industry.
2017.5 RPod 179
2 Weiner dogs
