| Author |
Topic: Genset and AC Posted: 31 May 2017 at 4:01pm |
I happened on an old post from Toolman John I had forgotten. I tried this today with my Generac IQ 2000 and AC on my 178. It works.
"I have the same generator , a Honda EU2000i. It DOES run my A/C (13,500 btu) BUT BUT BUT..... I must turn off my battery main ( I installed a disconnect marine grade battery switch ).
Well, when the R-Pod is on shore power (plugged into an outlet or a generator, no difference to the pod) the FIRST thing the converter/charger tries to do is CHARGE your battery. Yep, this draws a lot of watts, even if your batteries are at full charge, the charger will try anyway. This somewhat is the straw that breaks the camels back. The little Honda can't charge a battery AND run the A/C simultaneously.
So by disconnecting the battery, the converter charger gives up quick. I run the generator plugged in for about a minute or two to warm up, then turn on the A/C and it starts right up. Give it a try. "
Thanks Toolman.
TheBum
Posted: 31 May 2017 at 4:16pm |
If this works, it might actually motivate me to install a cutoff switch.
Posted: 31 May 2017 at 4:18pm |
It works and you need that anyway, Bro.
Gregm
Posted: 31 May 2017 at 4:44pm |
This opens up several boondocking options for me in Florida during the hot season
Thanks
Gregm
2014 171
2015 Toyota Tacoma Prerunner
jwb
Posted: 31 May 2017 at 10:22pm |
you can also turn the breaker to the converter off. Does the same thing.
2017.5 R-Pod 180
Joel & Kindle
Seattle Wa
Posted: 01 Jun 2017 at 9:14am |
Question JWB - from yesterdays test. With genset attached, battery disconnected, I noticed the Pod had 12 volts on gauge, supplied by converter using the generator which simulates shore power. With converter CB off, I had nothing on gauge. In my mind the choice is - do you want to eliminate charge circuit or disable all 12 volts.
TheBum
Posted: 01 Jun 2017 at 11:01am |
This trick would probably also allow us to run the AC and microwave at the same time (using both generators). The problem wasn't source power: the 30A main breaker on the Pod would trip. The converter more or less idling would create some amperage overhead.
