Post Reply
Page <1 23456 8> |
| Author | |
Pod613
Joined: 11 Sep 2017 Location: Ottawa, Ontario Online Status: Offline Posts: 18 |
Topic: Towing setup for new RP176Posted: 18 Mar 2018 at 9:22pm |
I’m back with another question.
We purchased a 2018 RP176 and expect to get it in April, can’t wait! The dealer is advising me that I do not require a WDH with my Pilot. A stabilizer is all they recommend. They could up sell me easily but are not. My Pilot manual says my vehicle “should” not require a WDH but my gut tells me I should get one. It’s not a question of cost to me but safety. Thoughts?
2019 RP176
2016 Honda Pilot EX-L AWD |
malkbean2
Joined: 31 Jan 2017 Online Status: Offline Posts: 80 |
Posted: 19 Mar 2018 at 7:50am |
There is no advice being given - except perhaps yours. Stating factual experience is not advice and by the way I personally believe experience is way way way way more valuable than theoretical calculations and also keep in mind that any engineering spec worth its salt always throws in a fudge factor and 150% would not be uncommon. That being said, if you can afford it and it suits your needs, I believe it is always better to oversize your TV.
ArenaBlanca
Joined: 07 Sep 2016 Location: Alamogordo, NM Online Status: Offline Posts: 158 |
Posted: 19 Mar 2018 at 9:36am |
In light of the comment about the value of experience, I would say you could safely tow from the dealer to home and then make the call. I would also check to see if the TV is level when the Pod is connected. If you are towing when headlights are needed, you don't want the headlight pointing at the stars.
Enjoy Life!!
Joined: 25 Jul 2011 Location: Central KY Online Status: Offline Posts: 6128 |
Posted: 19 Mar 2018 at 9:45am |
As I remember, the Pilot and Ridgie manuals advise against a WDH, because if improperly installed or adjusted, they could damage the unibody construction.I know owners of both, who do both. Towing comfort is subjective.
That said. I (I) believe towing trailers, is "truck stuff", and I believe doing truck stuff requires.... a truck. Do people tow with Subarus and Kias and Escapes and such? sure. Would I? Nope. |
Pod613
Posted: 19 Mar 2018 at 11:26am |
The 2016 manual now says "Your vehicle is designed to tow without the need for a load distributing hitch. If you want to use one consult your trailer maker for proper installation and set-up. Improper set-up could degrade the handling, stability and braking performance of your vehicle" Anyway, I think the solution is simple, I can try it without and then put it on if required.
2019 RP176
Posted: 19 Mar 2018 at 11:42am |
Solid decision.
Make sure the basics are covered.. level to slightly nose down trailer attitude. 10-15% of total weight as tongue weight. Empty tanks if at all possible. Tow at a reasonable speed. Pod tires at 50 psi, or 65 if upgraded tires. |
lostagain
Posted: 19 Mar 2018 at 2:36pm |
I agree that it's best to tow with a truck or a SUV built on a truck chassis if you're towing something as big an r-Pod. It's safer for everyone and is certainly much more comfortable for those in the TV.
I would remove my signature block, but I don't care if I offend those who don't drive Dodges; it's their folly. And as to not leaving footprints, I learned that in the Boy Scouts in 1958 so it has to be true.
Andy
Joined: 11 Feb 2018 Location: Texas Online Status: Offline Posts: 65 |
Posted: 19 Mar 2018 at 4:30pm |
I would agree that this TV is not right. We have a 179 (Hood River Edition) that the salesman and sales manager both said was adequate. I was leery about taking their advice but once i'd shelled out the $ for the trailer I did not want to buy another TV. Was I wrong! so now I have a Silverado 1500 V8 4x4 with rear axle ratio of 4.2 and it pulls like a charm. I also use a WDH and sway bar. Good luck and enjoy the R-pod.
2017 179
2016 Silverado Z71 |
Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6465 |
Posted: 20 Mar 2018 at 11:01am |
I thought it was "leave only footprints." abbreviated from "Take only pictures, leave only footprints." |
lostagain
Posted: 20 Mar 2018 at 1:44pm |
Depends on where you're walking I suppose. But there are some places where we should not even walk, for example delicate meadows and bogs.
The guy who said take pictures and leave only footprints had the right idea for sure. Maybe troop 13 was more strict?
Post Reply
Page <1 23456 8> |
