  New Posts New Posts RSS Feed: Generator Problem...
Topic ClosedGenerator Problem...
jmsokol View Drop Down
Direct Link To This Post Topic: Generator Problem...
    Posted: 16 Jun 2014 at 8:45pm
Originally posted by Camper Bob
Thank you both. I don't seem to have any sensitive electronic gear on the road with me I haven't ever used the surge suppressor with the generator. I certainly have when powering from a pedestal at a campground. Other than very sensitive electronics, is it necessary to use the surge suppressor with the generator? Should I fabricate a G-N bond even though everything seems to work properly now? Safe Travels.
I personally think it's best that all 120-volt AC systems have a G-N bond. So if your shore power connection DOES supply it, and your portable generator DOESN'T supply it, then YOU should supply it with an external G-N bonding plug. Just a reminder, this does NOT plug into an outlet inside of your RV. It must only be plugged into a spare Edison outlet on your Generator.
FYI: All generators that are built-into larger RVs already have the G-N bonding function supplied by the transfer switch. Since you don't have a generator transfer switch in your "Pods" then this takes the place of one.
mike@noshockzone.org
www.noshockzone.org
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 16 Jun 2014 at 8:58pm
A modern inverter generator arguably probably doesn't need a surge protector.  I'm sure there a scenarios were it might be a good idea with such a generator, but the thing is, if you permanently install a surge protector for those times when you're using no telling what kind of shore power, you're stuck with having it inline when you're using the generator.  It's simple and cheap to do the G-N bonding plug.
TT
FJ Cruiser
Camper Bob View Drop Down
Direct Link To This Post Posted: 17 Jun 2014 at 12:38am
Aha, said the blind man. I got it. So off to the hardware store for an openable plug and will put in the jumper and plug it into one of the Edison plugs. Never knew they were called that. Safe Travels.
Camper Bob and Camper Sue
2013 Rpod 171HRE(ORPod)
2016 Lance 1685
2015 Nissan Pathfinder
Cookpod View Drop Down
Direct Link To This Post Posted: 17 Jun 2014 at 1:12am
Just want to say thanks for the contributions here. Learning a lot and appreciate the posters willing to share their knowledge.
Cap-n-Cray View Drop Down
Direct Link To This Post Posted: 17 Jun 2014 at 1:15am
A wall plug is called a duplex outlet or duplex receptacle...
Cary
2014 RP-177
Direct Link To This Post Posted: 17 Jun 2014 at 2:47am
Yes, pro-sound guys call them Edison outlets and plugs in America since that's the man who invented them. But you electricians and engineers also know they're officially called NEMA 5-15 or 5-20 connectors. Smile
http://en.wikipedia.org/wiki/NEMA_connector
www.noshockzone.org
