r-pod 196 Wheel Camber |
Post Reply
Page <123 |
| Author | |
Post Options
Quote Reply
Topic: r-pod 196 Wheel CamberPosted: 30 Nov 2021 at 3:59pm |
To be more clear, there is a safety
built into the axle rating. I don't know what it is for the 196, but when I did the math for the 179 a few years ago I came up with a safety factor of a bit less than 2x, so a 3500 lb rated 179 axle can handle around 7000 lbs before failing. That means that the axle could fail with about a 2 g bump load on it. That's not enough to handle bumps and potholes. Hence the common issue of bent axles on the 179's. Since you have a 196 YMMV but the general concept is the same. |
Post Reply
Page <123 |
