  New Posts New Posts RSS Feed: Fresh water tank
Topic ClosedFresh water tank
Direct Link To This Post Topic: Fresh water tank
    Posted: 06 Feb 2021 at 7:40am
Originally posted by Pod People
We mounted our water pump on a 1.5" dense foam block and insulated all of the water lines.  It made things a lot quieter.
Vann
Thanks for that great idea.  Had been mulling over using a piece of 1" rigid 3M foam they use to insulate homes with.  Seeing how you did a similar setup - this will be a go.  Will only have to use longer wood screws to fasten it into the floor.
RoverPod View Drop Down
Direct Link To This Post Posted: 07 Feb 2021 at 5:38am
Buckeye, the most common cause of this is the check valve in the water pump getting stuck. Disconnect the city water and cycle the water pump a few times to clear and reset the valve.
2017 F150 XLT SuperCab
2020 rPod 180
