Post Reply
Page <12 |
| Author | |
Topic: No powerPosted: 01 Sep 2016 at 10:26am |
That would be my suspicion. A multimeter (sometimes available for free from Harbor Freight with other purchase) is handy to help diagnose things like this. That is also why I suggested checking the two 40A fuses.
DawgLady
Joined: 11 Apr 2016 Location: Ashburn, Georgi Online Status: Offline Posts: 94 |
Posted: 01 Sep 2016 at 10:43am |
Thanks so much!!
Dawg Lady
2016 R-180 "Lizzy" Georgia |
densmorema
Joined: 25 Jul 2016 Online Status: Offline Posts: 70 |
Posted: 02 Sep 2016 at 10:10am |
If you are hooked up to shore power all your light should be working off the converter and also be charging your battery, if you checked the breakers than I would check the converter fuses they are the 40a fuses.They may have blown one when they were working on your slide out.
Mike and Cherie
Michigan 2015 R179 2016 silverado |
DawgLady
Posted: 02 Sep 2016 at 10:13am |
Thank you, I will check them.
Dawg Lady
Shelpod
Joined: 14 Sep 2015 Location: Arizona Online Status: Offline Posts: 74 |
Posted: 02 Sep 2016 at 10:53am |
Are you hooked up to a 30 amp connection or are you just running from an outside outlet from your house. That is how we have to hook up and occasionally we kick the GFI for our house which also runs the outside outlet. If you aren't getting any power anywhere, that could be your problem.
Pod: 2013 178
TV: 2014 Explorer Limited with tow package |
Post Reply
Page <12 |
