  New Posts New Posts RSS Feed: Battery Charging
Topic ClosedBattery Charging
Direct Link To This Post Topic: Battery Charging
    Posted: 24 Feb 2016 at 8:41pm
Make sure you disconnect the battery from the pod if you don't leave the pod plugged into AC power.  The built-in charger will have no problem charging a low battery.
Bret View Drop Down
Direct Link To This Post Posted: 10 Mar 2016 at 11:59pm
Thanks for all of the input.  Great forum!  I purchased the Genius 3500 charger but not sure I am getting a full charge, even after multiple days of charging.  Instructions say fully charged is indicated by green light being solid (not blinking) and other three buttons (25%, 50% and 75%) are off.  Beast I can get is blinking green light and other three lights lit.  I guess I will see how charged batteries are when I head out to camp.
It sounds like you get some charging of the batteries while driving but not sure how much it is.  Any good information from experience??
hogone View Drop Down
Direct Link To This Post Posted: 11 Mar 2016 at 6:23am
and just to confirm, disconnecting the battery means the negative terminal, correct?  hogone
Jon & Pam
2025 GD 17MKE
2013 RP177(sold Nov 25)
2023 F150
2017 HD Streetglide
CHEESEHEAD
Direct Link To This Post Posted: 11 Mar 2016 at 9:36am
See my post here on page 2 for why you should disconnect the negative terminal:
http://www.rpod-owners.com/forum_posts.asp?TID=7546&PN=2&title=battery-disconnect
