  New Posts New Posts RSS Feed: Water heater HELP!!!
Topic ClosedWater heater HELP!!!
Jamie&Nicole View Drop Down
Direct Link To This Post Topic: Water heater HELP!!!
    Posted: 23 May 2015 at 11:39pm
Yes we purged the lines when initially setting up. However it ha worked to re-purge them, any ideas? Maybe just have dealer look?
Direct Link To This Post Posted: 23 May 2015 at 11:29pm
If you purged the lines when you turned on the propane you shouldn't have to do it again during the same trip.
Direct Link To This Post Posted: 23 May 2015 at 10:30am
Thanks Guys! We did light bunner intaily when setting up camp and turning in the propane, we we not aware that we would need to do so again even after the intail time when turning on propane. Easy fix tho!!! Thank you all hope everyone is having a great Memorial Day weekend!
Direct Link To This Post Posted: 23 May 2015 at 9:29am
There is no pilot light. DSI stands for Direct Spark Ignition. It lights when it needs to light, shuts off when done. If it tries 3 times, and doesn't light, it "faults" and you get the light on on the panel. Shut off and let it try again. It may take several tries for the gas to get back there. Lighting a burner for a few seconds will purge the line, and you won't have to go through this.
Podster View Drop Down
Direct Link To This Post Posted: 23 May 2015 at 12:33am
Probably just air in the lines. Make sure the valve on the propane tank is all the way open and purge the air in the lines by lighting each burner for 15 seconds. Then try it again.
Edit: There is also two reset buttons on the outside, you can try those if this doesn't work.
Cliff & Raelynn
Ranger 4.0/178
Direct Link To This Post Posted: 23 May 2015 at 12:03am
3rd time out in our new pod! No issues the 1st two times but this time we notice the water heater pilot light keeps going off. The DSL fault light comes on and the pilot tries to light itself numerous times but is not usually successful when we switch off and on the water heater it will usually relight after a couple tries. Just wondering if any may know what is going on or had similar issue? Thanks for all your help in advance!
