| Author |
danielppd
Topic: Soon-to-be Podder: 182G questions Posted: 25 Mar 2014 at 11:03am |
Got it. Purpose of the topper? I assume it's already waterproof.
wingnut2312
Posted: 25 Mar 2014 at 11:05am |
The slide out can collect water, leaves, debris and other junk. The topper keeps it off and out of the pod.
2014 rpod 182G
Ford Expedition
danielppd
Posted: 25 Mar 2014 at 11:08am |
Ah. Ok, so did you install it or did the dealer?
Also, with the axle riser, does it raise the pod portion up? How important do you think this is to have?
wingnut2312
Posted: 25 Mar 2014 at 11:17am |
I had them do both. The topper would just be nice to have. The riser raises the pod and makes the rdome not touch the ground perfectly. Depends on the kind of camping you're doing. I got both because why not.
2014 rpod 182G
Ford Expedition
CharlieM
Posted: 25 Mar 2014 at 12:12pm |
IMHO the risers are a must. Even if you stay on paved roads, just one encounter with a gas station entry where you rip off the rear stabilizers will prove their worth. True, the RDome fit is awkward, but it's very workable. The slide topper is also well worth it. Mainly keeps crud (dirt, leaves, snow, water) from accumulating and interfering with closing the slide. Also, consider upgrading the sewer hose to a 15 foot RhinoFlex hose and mounting a 60" hose carrier tube underneath the Pod.
Posted: 25 Mar 2014 at 1:02pm |
I always chuckle when I see "axle riser". Technically the axle stays at the same level. It should be called "pod riser".
Hairy Podders
Posted: 25 Mar 2014 at 8:05pm |
Or, like my Jeep; a lift kit.
Which causes a new delimma. My Jeep only has a 2"lift....
Darryl, Julie & Lindsey
2014 RP178
