  New Posts New Posts RSS Feed: New (to me) 2016 RP178
Topic ClosedNew (to me) 2016 RP178
Tomtreas View Drop Down
Direct Link To This Post Topic: New (to me) 2016 RP178
    Posted: 08 May 2020 at 8:41pm
I have mine hooked up.  On a recent outage I went to Target and picked up a 6' RCA male to male stereo cable.  During that outing I just used the AV cable and plugged into the front AUX jack and just plugged the RCA stereo audio out on the TV to the audio for that cable.  When I got the Jensen stereo out, I looked at the back and discovered that the AUX 1 is AUDIO ONLY and consists of two RCA female left and right inputs.  It is marked as such.  I'm attempting to include a photo of this with that input circled.  I didn't get fancy with the cabling but just dropped it down so that I could retrieve it from behind the AV cable plate and just let the wire come out the side.  That gave me just enough to plug it into the back of the stereo easily and still have just enough to make along the plastic cable wrap and over to the TV audio output.  Works like a charm!
Direct Link To This Post Posted: 08 May 2020 at 8:44pm
Originally posted by StephenH
I think you would be better served by getting a small set with a driver handle and assorted bits.
I actually did find that I had a bit collection that has some in it that have longer shanks than your garden variety multi-tip screwdriver and those worked well.  The holes in the stereo are kinda deep so I needed the extra shank length.  See my other post for my solution on getting the TV audio to the rear AUX input on the stereo. =)
Thanks for your help and keep up the great stuff!!
jimandclare View Drop Down
Direct Link To This Post Posted: 09 May 2020 at 6:32am
WHAT???  This is great!  A bit embarrassing  also.  The manual indicates a mini input jack socket in another location and I never once looked for anything else.  Thanks for the post/picture Tomtreas.  Looks like I have another good shelter in place project for today.
Jim & Clare
2016 R-pod 178
2014 Ford Edge
Direct Link To This Post Posted: 09 May 2020 at 8:04am
My pleasure. Yes, the longer shank bits are quite helpful. I have a lot of the short ones but only a few of the long shank ones. They are the ones that get used the most.
