  New Posts New Posts RSS Feed: Load equalizer - Sway control
Topic ClosedLoad equalizer - Sway control
Greg View Drop Down
Direct Link To This Post Topic: Load equalizer - Sway control
    Posted: 07 Apr 2016 at 10:41pm
I'm purchasing an R-Pod 179 to pull behind my 2012 Nissan Murano. The Murano has a 3,500 Lb tow limit so that's OK. What I want to know is what folks think about a weight distribution/sway bar system for the trailer.
I'm looking at the Blue Ox Sway Pro that has a 350 tongue rate which works with the 285 for the r-p. While the system is expensive, you can back up without having to remove it and the tension chains are on a roll up wheel as opposed to a cam-over lever system. I like both of these.
I want to make sure that when my wife is driving, she feels secure with the trailer back there and we don't have to worry about wind, trucks, etc.
Thanks for any help you have to offer
GLBCamper View Drop Down
Direct Link To This Post Posted: 07 Apr 2016 at 11:24pm
Not to be negative, but I bought my 177 intending to tow with my v6 Ford Escape also rated @ 3500lbs. After one (very short) trip I found that tow ratings should be taken with a grain of salt. I bought the Tacoma the next day. It's rated at 6500lbs and I still worry that I should have gone with the Tundra.
Old: 2014 177 HRE
2015 Tacoma V6 4x4 Double Cab
New: 2016 EVO ATS 200rd
2016 F150 4x4 Sport
Direct Link To This Post Posted: 08 Apr 2016 at 9:13am
Welcome to the forum!
I'm not at all familiar with the Blue OX so, I can't comment. The Fastway E2 is popular among the group and here is a recent thread:
E2 posts
Good luck!
Direct Link To This Post Posted: 08 Apr 2016 at 9:22am
Welcome! The Equal-i-zer 4-way sway control hitch is also one to consider. There is another one that I have read about but have not tried--the Andersen no-sway hitch.
SandD View Drop Down
Direct Link To This Post Posted: 08 Apr 2016 at 8:04pm
I have a 178 with an 06 Tacoma trad Prerunner crew 2wdh. Only used a sway bar. Ok if fresh water tank is empty.
Heard a lot about the E2 0600 so bought one. Having problems.
Center of truck receiver is 17 1/2" high. Using the bottom holes of the shank and 7 washers the RPOD sits 2" higher in front than back. Not good.
The camper has the risers.
Anyone have this problem?
Called e trailer and they said they would sell me a longer shank. Not cheap.
Like the set up if it worked.
There are two types of people in the world. Those who like RPODs and those who are wrong.
Rpodder
2014 RPOD 178
06 Tacoma Prerunner TRD
Direct Link To This Post Posted: 08 Apr 2016 at 8:21pm
Yes, if you are bottomed out on the holes, you need a longer drop shank.. we have no risers and tow with a Expedition, our shank is really long..
Direct Link To This Post Posted: 08 Apr 2016 at 8:51pm
towing with an expedition and longer shank? How much clearance under the shank and have you ever drug it?
Rpodder
2014 RPOD 178
Direct Link To This Post Posted: 08 Apr 2016 at 10:26pm
Yes, it has drug once or twice. I don't leave it in when not towing. But, with a low Pod, and a larger SUV.. you do what you have to do..
Greg View Drop Down
Direct Link To This Post Posted: 08 Apr 2016 at 11:14pm
Thanks for all your replies. Now I'm really worried about the 3,500 lb towing capacity of the Murano. Nissan has a Class II hitch and rates it for towing, but the two Nissan mechanics I talked to said don't tow anything with a Murano. Now I don't know what to do. A new vehicle is out of the question. Does anyone out there tow their R-Pod with a Murano?
I need to make a decision by Monday when my loan papers go through. Help
Greg View Drop Down
Direct Link To This Post Posted: 08 Apr 2016 at 11:20pm
