  New Posts New Posts RSS Feed: $30 Lift Kit
Topic Closed$30 Lift Kit
NXRocks View Drop Down
Direct Link To This Post Topic: $30 Lift Kit
    Posted: 19 May 2014 at 11:19pm
2x4x3/16" - 12" - $10 (per side)
Hardware - $10
4 holes to drill (per side)
Total time - 2 hrs
If you are just a bit handy - you'll figure this out. It is stronger, better and will cost you a lot cheaper than the outrageously expensive one going around for as much as $200
I did weld the corners - just because I'm crazy and I overbuild everything - but is not necessary. If I ever have to take the axle out - it will take me 10 mins to cut that weld.
All the hardware should be minimum grade 5
Have fun !
2009 R-Pod 172 Lifted 4"
2008 Nissan Xterra built up - too much to list
Computer Engineer with metal work as a hobby - or more - former NXRocks manufacturing
First time RV Camper - this better be good
Craneman View Drop Down
Direct Link To This Post Posted: 19 May 2014 at 11:25pm
Wow nice job, I should have went that route
      Moe
Jo and Gary
2010 174
2011 Ford 150
Hairy Podders View Drop Down
Direct Link To This Post Posted: 20 May 2014 at 7:04am
Looks very nice!
Our lift was included in the super low price, so that saved me the time.
Darryl, Julie & Lindsey
2014 RP178
Direct Link To This Post Posted: 20 May 2014 at 8:07am
Very nicely done. How did you lift the trailer for installation?
Direct Link To This Post Posted: 20 May 2014 at 8:34am
On each side - lift the RV from under the axle, jack stands, take the wheel off, take the bolts off, lower the axle, put the new spacer, put the bolts, raise the axle, put the wheel, take the jack stands off, lower the axle.
One important thing - mark the alignment of the trailer frame and the axle. I used a masking tape
Direct Link To This Post Posted: 20 May 2014 at 8:39am
Very nice looking.
gpod View Drop Down
Direct Link To This Post Posted: 02 Jul 2014 at 7:44pm
Where did you get the 2x4x3/16" risers that you used?  Were they pre-made and bought that way or did you have them custom-made somewhere?
Tnx!
Matt
Seanl View Drop Down
Direct Link To This Post Posted: 03 Jul 2014 at 7:51am
Tnx!
Looks like 2X4 Steel tubing you can get it an any steel supplier.
Direct Link To This Post Posted: 03 Jul 2014 at 9:33am
As Sean said ... any steel supplier would have that - or get it online (while it will cost more) here for example: http://www.speedymetals.com/pc-4713-8224-4-x-2-x-188-wall-rectangular-steel-tubing.aspx
gpod View Drop Down
Direct Link To This Post Posted: 03 Jul 2014 at 10:13am
Thanks for the info!  Looks like you're close by.  I'm in Golden.  Let me know if you ever want to meet up for a beer and compare rpod notes!
Matt
