Fresh water drain |
Post Reply
| Author | |
Mtngrannie
Joined: 25 Sep 2023 Online Status: Offline Posts: 1 |
Post Options
Quote Reply
Topic: Fresh water drainPosted: 02 Oct 2023 at 7:43pm |
New to forum.
I'm an old lady with a 2012 Frog. Getting to the fresh water drain plug is tough for me. Has anyone found an easier solution to draining the fresh water tank? |
EchoGale
Joined: 10 Mar 2019 Location: FL Online Status: Offline Posts: 469 |
Post Options
Quote Reply
Posted: 03 Oct 2023 at 7:47pm |
Hi there...it isn't located in the easiest spot, is it? Depending on how full the tank is you could run your fawcett and shower hose and then empty the gray tank....
Julie
Joined: 29 Nov 2015 Location: Wake Forest, NC Online Status: Offline Posts: 6476 |
Post Options
Quote Reply
Posted: 04 Oct 2023 at 11:15am |
You could also (probably with help) put an elbow on the drain and run a section of hose out to the side where you can reach it. I would put a valve on it instead of using another plug if you do so. That should make it easier.
lostagain
Post Options
Quote Reply
Posted: 04 Oct 2023 at 2:51pm |
It would be easy to put an elbow and a length of pipe to the side of the trailer with a valve at the end, but it is something that could get knocked off by road stuff, especially if there is limited clearance under the tank. The length of pipe would have to be well supported to protect it from damaging the tank fitting.
EchoGale
Post Options
Quote Reply
Posted: 05 Oct 2023 at 10:44am |
That's what you get here. :)
1) well-planned options from/for folks with, skills, contacts, or money 2) work-arounds from/for those without lol
Julie
Post Reply
