  New Posts New Posts RSS Feed: I need help
Topic ClosedI need help
Jrfich View Drop Down
Direct Link To This Post Topic: I need help
    Posted: 07 Jun 2021 at 6:13am
Hello
Just purchased a 2021 r-pod 196. We bought this camper 1200 miles away from where we live mainly because no one around us had any. I have no 12 volt power at all. Battery is great. I metered it at 12.8v. My awning works as well as my power hitch. Other than that,no 112 v power . When shore power is connected, everything works great and battery shows full charge in display. It’s under warranty but I feel like my local dealer(100 miles away) is gonna give me a problem. I have also checked the busman fuse under the camper and have 12volts on both posts so I’m pretty sure that’s working. Any ideas are greatly appreciated.
Direct Link To This Post Posted: 07 Jun 2021 at 6:15am
Sorry in my post the 112 volts is a mistake it should be 12 volts. I didn’t proof read
Direct Link To This Post Posted: 07 Jun 2021 at 7:36am
Check the voltages at the fuse panel itself, could be one or both of your main 40a fuses are blown it not making contact.
Direct Link To This Post Posted: 07 Jun 2021 at 7:49am
Ok thanks will do at once
Direct Link To This Post Posted: 07 Jun 2021 at 7:57am
Tthat was it ! Had a blown 30a fuse that I neglected to check. Thank you so much!
EchoGale View Drop Down
Direct Link To This Post Posted: 07 Jun 2021 at 9:21am
This may sound like a dumb question, and i'm sorry for that,  but would someone please explain *how* to check the fuses?  Confused
Julie
GlueGuy View Drop Down
Direct Link To This Post Posted: 07 Jun 2021 at 9:59am
The fuses are all "mini" fuses and have a little window that allows you to actually see the fusible link inside. Without tools, you can just pull one out, turn it sideways and see if the link is broken or not.
If you're good with a multimeter, you can "sometimes" measure the voltage on both sides of the fuse. If the voltages are the same at both ends of the fuse; it's working. This is not always possible though, as often the connectors are not always reachable.
Direct Link To This Post Posted: 07 Jun 2021 at 11:20am
thank you
Julie
podwerkz View Drop Down
Direct Link To This Post Posted: 07 Jun 2021 at 11:48am
And on my WFCO converter, there are red LEDs that will indicate if a fuse is blown...
Direct Link To This Post Posted: 07 Jun 2021 at 12:44pm
Wow didn’t know that about the red led lights thanks
