  New Posts New Posts RSS Feed: New Rpod 178 owner
Topic ClosedNew Rpod 178 owner
Finpod View Drop Down
Direct Link To This Post Topic: New Rpod 178 owner
    Posted: 23 Feb 2021 at 10:00pm
Hi everyone! We’re new to Rpod but been tent camping for years. Here's our quick story.  We bought a Casita when the pandemic started. Eventually it or proved to be too small. I’m 6'2. Now moved on to a 2017 Rpod 178.we think this is our camper for many years.  So excited. TV is a 2017 SantaFe with 5000 lb towing capacity. Installing a weight distribution hitch tomorrow. Appreciate any suggestions,input. Glad to be here.
Thx
Fin
Direct Link To This Post Posted: 23 Feb 2021 at 10:21pm
Searching the forum will be of great benefit. Use the advanced search function though. It will allow you to search older posts. The default search is for six months and newer posts. Some very useful posts will be older and won't show up in a regular search.
I have done a number of mods on our 179. Since it is similar to the 178, some may be of use for you. See them in my mods, the link of which is in my signature.
Welcome to the RPod community. I had originally wanted to get a Casita, but got scammed instead. I'm glad I wound up with our 179. My wife and I have been much happier with out 179 than we would have been with the much smaller Casita.
Direct Link To This Post Posted: 24 Feb 2021 at 5:46am
Welcome.
I agree with StephenH, you will find the 178 much more comfortable than the Casita. The slide will make it feel much larger as well. The downside of an rpod over a Casita is build quality and water proofing. By getting a used one you will probably get the benefit of the first owner having sorted out the initial build issues but do inspect carefully.
The construction of the rpods is very different from the Casitas and you have to be particularly vigilant about water entry and damage. Two key areas are around the slide and under the rear spoiler. But do look for floor damage around the whole perimeter of the trailer. Also check for any plumbing leaks under the bath and kitchen sink. Beyond that the actual appliances in the two trailers and in most RVs are the same.
The Santa Fe will tow the 177 ok, my Highlander has the same rating, But you will need to watch your weights in the TV and trailer, and especially the tongue weight, to stay in spec. You don’t have a lot of headroom in your TV capacity, and neither do I. Especially if you plan on boon docking, with water and an extra battery/propane cylinder, you will quickly exceed your TV specs.
I highly recommend you load up the trailer and TV with everything and everybody you plan to travel with and go to a public scale. Weigh the rig adding an axle at a time, then drop the trailer and weigh the TV adding an axle at a time. Leave your wdh installed but not tensioned for the weighings. You can get the trailer, tongue, and each axle weight by subtraction. Put all your specs and actual weights in this calculator and see how much headroom you do or don’t have. The calculator will also show you the effects of adding tension to your wdh.
https://www.ajdesigner.com/apptrailertow/weightdistributionhitch.php
mcarter View Drop Down
Direct Link To This Post Posted: 24 Feb 2021 at 4:00pm
Fin, I have a 2015 178, owned since new, any 178 questions I'd be happy to answer.  We have been pleased with 178.
Direct Link To This Post Posted: 24 Feb 2021 at 4:06pm
178 owners are genetically superior. Just sayin...Tongue
Direct Link To This Post Posted: 24 Feb 2021 at 7:11pm
But 179 owners have an additional IQ point so environment trumps genetics in this case. Of course, all rpod owners are in genius territory so there’s no reason to quibble.
Direct Link To This Post Posted: 25 Feb 2021 at 9:14pm
Thank you!
Dirt Sifter View Drop Down
Direct Link To This Post Posted: 26 Feb 2021 at 9:47pm
Welcome to the genius territory, I mean forum from Eastern OR. You came to the right place for entertainment and information on your next pod CryBig smile Be safe.
Greg n Deb 2020 195 HRE
Winterpod View Drop Down
Direct Link To This Post Posted: 27 Feb 2021 at 2:43pm
I bought my 178 new in 2013. Have camped all over west of the Mississippi and never had a problem.
178 owners are specialLOL
Winter pod
2013 R-Pod 178
2007 Silverato 1500 LT.
Trek Stash 8 29er hard tail
Old Town Kayak
Direct Link To This Post Posted: 15 Mar 2021 at 11:41am
Thank you! Sorry for the late reply.
