  New Posts New Posts RSS Feed: 2017 R POD 178 Actual height
Topic Closed2017 R POD 178 Actual height - Event Date: 31 Jul 2018 - 31 Aug 2018
Barryb125 View Drop Down
Direct Link To This Post Calendar Event: 2017 R POD 178 Actual height
    Posted: 31 Jul 2018 at 6:06pm
Hello R Pod'rs
I have a 2017 R Pod model 178 with the stock a/c unit (that I will probably never use). Can someone confirm the actual height of 9'5" is the height including the a/c unit?
Thanks
Barryb
mcarter View Drop Down
Direct Link To This Post Posted: 31 Jul 2018 at 6:19pm
The spec height is 9.7".
Barryb View Drop Down
Direct Link To This Post Posted: 31 Jul 2018 at 6:58pm
Thanks Mike;
I am new to the r pod world, do you know if the water pump is compatible with pumping water from a water container and into the fresh water holding tank?
Thanks
Barry
Direct Link To This Post Posted: 01 Aug 2018 at 7:16am
Originally posted by Barryb
Thanks Mike;
Thanks
Barry
No it is not. For people who have such a need, buying a small pump, or using one powered by a cordless drill, and moving water works. Or just plain old gravity.
mjlrpod View Drop Down
Direct Link To This Post Posted: 01 Aug 2018 at 8:23am
Hmmmm I believe my pod is 9 foot 3 inch. I better recheck this number, before I have a 4 inch mishap
2017.5 Rp-172
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Direct Link To This Post Posted: 01 Aug 2018 at 8:27am
Forest River latest specs for a 172 is 9.6", might make a difference if you have 14" tires. New models have 15" tires.
Direct Link To This Post Posted: 01 Aug 2018 at 8:48am
My pod absolutely measures 9 foot 2 1/2 inches over the A/C unit (I remeasured). I assume not all pods measure the same. It could easily fluctuate a couple inches. I have 14 inch tires, so the newest pods are going to be higher with 15 inch (i assume they didn't lower the roof to accommodate new tires). I don't know if the "hitched height" changes it either. I think 9 foot 7 inches might be a smart number to use as a minimum. (just a side note: 9.6 is not the same as 9'6")
2017.5 Rp-172
2020 R-pod 195
I'll be rpodding
wooleeman View Drop Down
Direct Link To This Post Posted: 02 Aug 2018 at 12:26pm
I worked in a truck shop for many years and remember the box trucks and trailers that hit the bridges. I just figure on 10 feet.  Easy to remember and allows for those bridges that just had the road resurfaced under them and measurement not changed.
2022 RP-202
2016 RP-179 (Sold 9/2020)
2014 Silverado Crew Cab. 6-1/2' Bed
Golden Retriever (DOB 6/16/2020)
English Bulldog (RIP 6/15/2020)
GlueGuy View Drop Down
Direct Link To This Post Posted: 02 Aug 2018 at 1:19pm
Never worked in a truck shop, but I remember when I read about our R-pod and remember 9 feet plus some change (maybe around 9.5 feet). At any rate, instead of remembering what the change was, I just made a mental note of 10 feet. If you have 10 feet, you should be good.
The Hood River pods have 15" tires and are about 3" higher off the ground. So there is that too.
Direct Link To This Post Posted: 02 Aug 2018 at 3:02pm
+1, I would try and check it out on something close to an advertised height, some spare clearance would be important. I can enter trailer height in my GPS and it warns me when I am approaching a clearance issue. BTW - I use 10'.
