| Author |
sean p
Topic: better antenna? Posted: 28 May 2018 at 6:58am |
Is there a better antenna i can get for my 179. The radio im sure could pick up better reception with a diffrent antenna. Do the batwing antennas pick up more radio reception. I get over 50 hd channels at home with the current antenna.
2016 179pod--BETTY
2010 nissan frontier
Sean and Doug
Butchie the morkie
touring the west
Pod People
Posted: 28 May 2018 at 8:19am |
are you engaging the antenna booster? It is the small button on the same faceplate as the antenna input cable. Vann
Vann & Laura 2015 RPod 179
sean p
Posted: 28 May 2018 at 8:31am |
Well good heavens. I'll give it a try. was never aware of its function,thought it was for cable imput. Thanks
2016 179pod--BETTY
Sean and Doug
Butchie the morkie
touring the west
crankster78
Posted: 28 May 2018 at 9:00am |
Greetings I put a bookshelf Stereo system in my 179. I attached a 3 foot post to the hitch area, have 3 sections of light tv mast and put a omidirectional FM antenna on top. I use a piece of coax to plug it in to the outside plug. It sounds and receives great. It takes about 5 minutes to set up and take down.
Crankster78
Crankster 78 R-179 2015
mjlrpod
Posted: 28 May 2018 at 5:34pm |
I don't know why you have to turn on the antennae booster separately. You almost CANNOT either watch t.v. or listen to the radio without turning on the booster switch, yet, it's a whole different button. THEN you have to remember to shut it OFF or kill your battery. What do I know.
2017.5 Rp-172
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
ZuBrew
Posted: 29 May 2018 at 9:01am |
Crankster78 |
Crankster, Could you send more info and some pictures for this antenna setup you have? We just camped about 20 miles from our local city and I couldn't pick up any channels. Thanks.
2017 Chevy Silverado 1500 4X4
2018 R-Pod 189
2013 Yamaha FJR 1300A
crankster78
Posted: 29 May 2018 at 9:24am |
Greetings Go to Amazon, enter outdoor FM antennas, Look for a omnidirectional. If I remember, they are about $40. Get some cheap 5 foot sections of tv mast, a piece of 3/4 inch square tubing and a couple of clamps long enough to clamp the tubing to the hitch frame.. Get a piece of tv coax long enough to reach the plug on the side of the cabin. I also use an external amp. You could also install a small tv antenna in place of the FM. I use the mounted antenna for what little TV I watch. If you are going to use the installed radio, you may need to switch the coax to that unit by pulling it out { 4 screws)
I don't use it except when on battery.
Crankster78
TheBum
Posted: 29 May 2018 at 10:50am |
Originally posted by mjlrpod
I don't know why you have to turn on the antennae booster separately. You almost CANNOT either watch t.v. or listen to the radio without turning on the booster switch, yet, it's a whole different button. THEN you have to remember to shut it OFF or kill your battery. What do I know. |
If you go to a campground that has cable hookups and you want to one, you have to turn off the booster.
Alan
2022 R-Pod 196 "RaptoRPod"
2022 Ram 1500 Lone Star 4x4
Three cats
Tomcheryl
Posted: 29 May 2018 at 3:23pm |
BOOSTER???? what?? ok That would explain the crappy radio reception!! I just happen to have the pod in out front ..... I'm going to look for it now. Is it the face plate with the cable and satellite ? if it is, it looks like it has always been on??!! should i turn it off when not in use? our battery seems to drop quickly, I'm changing to two 6 v because of it. My husband and I are super newbies ,still learning. I'm all about the mods!! thanks Cheryl
Life is short,it’s time to roll
TheBum
Posted: 29 May 2018 at 3:26pm |
You're probably better off with a disconnect switch on your battery. There are a number of parasitic drains on the battery from various electronics; a disconnect switch will eliminate all of them.
Alan
Three cats
