  New Posts New Posts RSS Feed: Sewer smell in pod
Topic ClosedSewer smell in pod
rawest50 View Drop Down
Direct Link To This Post Topic: Sewer smell in pod
    Posted: 26 Oct 2017 at 2:32pm
We use the following to deodorize and clean Grey Water.
Walex TOI-61776 Elemonate Grey Water Deodorizer and Cleaner $8 for 10.
Deodorizes grey tank
• Freshens sink and drain lines
• Dissolves grease and organic sludge from drain lines and grey tank
• Bio-degradable
• Rapid dissolve tablet
and for Black Water we use. Walex BIO-11530 Bio-Pak Natural Holding Tank Deodorizer and Waste Digester. $12 for 10.
No need for special toilet paper (We use the camping paper).
• Deodorizes and breaks down waste and paper
• Pre-packaged portion control - no measuring or pouring
• Non-staining color
• Septic tank safe
Both do a pretty good job. If we are camping for 5+ days I usually have to add another tablet to the grey and packet to the black. This is the only one we have tried. Probably others as good.
2017.5 RPod 179
2017 Jeep Unlimited Wrangler
2 Weiner dogs
Great wife puts up with my BS
❤️ Thoroughbred Racing.
pgoelz View Drop Down
Direct Link To This Post Posted: 23 Oct 2017 at 10:18am
Also don't forget that the black water tank roof vent is close to the bathroom fan / vent.  I'm guessing that depending on wind direction it would be easy for fumes to waft back into the bathroom via the fan if the vent was left even partially open.  Not a big deal unless the pod is left closed up for a while.
Paul
2014 Rpod 171
2017 Toyota Highlander
TEDDY View Drop Down
Direct Link To This Post Posted: 23 Oct 2017 at 8:36am
What toilet chemical do you use? We are transitioning from an Aliner (using a potra-potty) to an rPod 178 - didn't seem to matter what chemical we used in the porta potty - just a few gallons capacity, but I think using the right chemical will be important in the 178.
Teddy
Danielw1 View Drop Down
Direct Link To This Post Posted: 05 Oct 2017 at 9:41pm
Wrong about that! Looks like the only hole in the top is the inlet
Direct Link To This Post Posted: 05 Oct 2017 at 9:29pm
I just found this from outlander website.. maybe it's the answer!! Makes total since:
"Finally, in the summer of 2008, I solved the problem.
There is an overflow tube that extends from right near where flush water enters the top of the bowl directly to the black water tank. This is apparently intended to keep the toilet from overflowing if there is a small leak in the water valve.
The tube is curved, forming an "S" trap. If there is no water in the "S", there is a direct passage between the black water tank and the bathroom. Thus - BAD odors in your living quarters - regardless of what chemicals are in the tank.
To fill the "S" with water, simply fill the toilet to the brim. Let it stand for a couple of minutes to make sure the overflow trap is filled, and flush it down. Then, just use the toilet normally. It would probably be a good idea to repeat this a few times during the camping season, just in case the trapped water is sloshed out or evaporates.
At any rate, we have had NO ODORS SINCE WE STARTED DOING THIS!"
For a diagram showing the overflow tube, see:
http://www.thetford....18/Default.aspx
PALOD
Direct Link To This Post Posted: 05 Oct 2017 at 9:05pm
http://www.thetford.com/part/aqua-magic-v-hand-flush/
The link will take you to a parts diagram with part numbers.
Direct Link To This Post Posted: 05 Oct 2017 at 8:59pm
I will try the different treatment. The one I'm currently using is camco tst, it says biodegradable.
Does anyone know what the part# is for the toilet gasket? I am sure it has to be coming from there. Thanks
shroomer View Drop Down
Direct Link To This Post Posted: 23 Sep 2017 at 6:16pm
+1 on the biologicals
Direct Link To This Post Posted: 23 Sep 2017 at 2:03pm
I have started using the biological treatments and the smell is definitely less than when I was using the blue  or green treatments. TankTechsRx or RV Digest-It are two that I have tried.
mjlrpod View Drop Down
Direct Link To This Post Posted: 23 Sep 2017 at 11:03am
I think there is a huge difference in the treatment you use also. I got the blue, thick , really gooey kind from thetford in a sample size to start. I then bought the orange cheaper type over the summer. I found i got sewer odor, and thought it must be because of the heat of summer. I then thought i'd buy the thick blue more expensive type to see if it made a difference. In MY opinion, without a doubt the thick blue gooey more expensive thetford treatment wins hands down. I have smelled nothing what so ever since going back. Even leaving the tank 1/3 full for 3 weeks. I also use grey tank treatment and i'm very careful about what goes in my drains. I wash all dishes outside with moist wipes before they ever get near the sink. i dont even pour leftover coffee in the sink. I have no real grey tank odor either.
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
