  New Posts New Posts RSS Feed: 18 volt drill
Topic Closed18 volt drill
Direct Link To This Post Topic: 18 volt drill
    Posted: 02 Sep 2017 at 6:36pm
+1. ToolmanJohn. Maybe we can take this off reoccurring posts.
ToolmanJohn View Drop Down
Direct Link To This Post Posted: 02 Sep 2017 at 6:17pm
Yes, others have said it, the Pod does NOT have leveling jacks!!! They are stabilization jacks ONLY!! If you try to level the Pod, they will bend.
You have to level side to side by driving the Pod low side tire up onto a block of wood, or plastic Lego levelers, or something similar. Or one of the BAL leveling chock/jacks, might also work.
If you actually unweight the Pod using a stabilizer, that jack will bend if the Pod moves at all front to back. Not good. I wouldn't even try using them to change a tire.
AND BTW, an 18 volt drill with a 3/4" CAMCO socket works GREAT. No need to exercise. Just drill away to lower or raise.
2013 R-Pod 177 (SOLD)
2013 VW Touareg TDI
eye95 View Drop Down
Direct Link To This Post Posted: 02 Sep 2017 at 7:10am
Timely reminder. New folks reading this thread may get a costly wrong impression.  Thanks.
<0>
2017 178 The "eye-Pod"
2011 Nissan Titan
sailor323 View Drop Down
Direct Link To This Post Posted: 02 Sep 2017 at 6:49am
BTW, the jacks on the pod are not leveling jacks.  They are for stabilization only.  use the tongue jack along with something under a tire for leveling
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 01 Sep 2017 at 10:43pm
I have a rear door instead of a tailgate, but taking off the crank makes very little difference in any kind of clearance.  If an inch or so would make the difference for you, it might work.
john in idaho View Drop Down
Direct Link To This Post Posted: 01 Sep 2017 at 6:22pm
By replacing the tongue jack handle, can you open the tailgate now?
Direct Link To This Post Posted: 01 Sep 2017 at 5:50pm
I took the crank off of my tongue jack and replaced it with a 3/4" nut.  My drill runs it up and down easily.  Electric tongue jack...
jprithch2 View Drop Down
Direct Link To This Post Posted: 01 Sep 2017 at 4:49pm
Thank you all!
Bucky Dutchman View Drop Down
Direct Link To This Post Posted: 01 Sep 2017 at 4:39pm
We just use the "manual" wrench that came with our R-pod.
Direct Link To This Post Posted: 01 Sep 2017 at 4:13pm
CAMCO makes a socket for stabilizers that has a bit end for electric drills, cheap, it is 3/4"
