condensed
Calendar Event: 2017 rpod 179 Posted: 28 Aug 2017 at 12:51pm |
We have a new 2017 rpod 179 that we pull with a GMC Sierra 1500 5.3 v8. The trailer is constantly fishtailing 4 to 5 inches with any wind or uneven road conditions. It is not heavily loaded when we travel. Has anyone experienced this condition and found a remedy for it ?
Thanks for any ideas
ohardy
ohardyIII
analogtime
Posted: 28 Aug 2017 at 12:57pm |
Are you using Weight Distributing Bars and Sway bars? They make a world of difference. Also make sure that any weight you ARE carrying in the POD is in the front end near the hitch. Check your tires. Low air will do this. And - of course - don't speed.
Leo B
Posted: 28 Aug 2017 at 1:03pm |
+1. Good tips!
ronahue
Posted: 28 Aug 2017 at 1:51pm |
Try filling your fresh water tank, the 179 trailers better with a full fresh water tank.
Ron & Sharon
2015 R-Pod 179
2022 Nissan Frontier
mjlrpod
Posted: 28 Aug 2017 at 3:57pm |
I cant help, my 172 totally stays put behind me, ive never seen it move even an inch. I dont have anywhere near the T.V. you have, i tow with a Nissan Frontier 6 cyl, but i do use WDH. That might be the difference, also, i have carlisle radial tires and make sure they are at 65 p.s.i. frequently.
2020 R-pod 195
2015 Frontier sv 4.0L 6cyl
I'll be rpodding
Posted: 28 Aug 2017 at 4:14pm |
A sway bar would help immensely, that is all I use. I do not have a WDH, not with a 1500 chevy and a Pod.
Posted: 28 Aug 2017 at 7:09pm |
ohardy |
You have some sort of rigging problem. You really shouldn't see any issues like that with that TV. It should easily handle up to 500# tongue weight, and not really need anti-sway or WDH.
That said, you may have the weight distributed incorrectly or some other thing. I would first weigh the R-pod, and the tongue weight and make sure you're within normal limits.
The R-179 should weigh between 2,800 and 3,800 pounds, with "about" 10% (280-380 lbs) on the tongue. Depending on how the rig is loaded, the tongue weight could be as much as 15% (420-570 lbs). So to rule of thumb it, expect ~~ 300-550 lbs on the tongue. If you're outside of that zone, then you may just need to move things around. If you're inside that zone, then you might very well consider a WDH, or anti-sway, or both.
We pull our R-179 with a Fastway E2 WDH which provides mild anti-sway in addition to the weight distribution, and we see zero sway or fishtailing. The F-150 and the R-179 go down the road as a "unit". No excitement.
Bama Pod
Posted: 29 Aug 2017 at 7:29am |
Also make sure she's not "nose-high".
Bama Pod
Huntsville, AL
2017 Ford F250
2017 Airstream 26U
Posted: 29 Aug 2017 at 8:44pm |
Bama, I believe you nailed it. The tongue should be level or slightly tilted down toward the front of the pod. With your pick up it may be 'nose up.' You can easily remedy that by getting a draw bar for your ball that has a drop so that your pod will sit level when hitched to your pickup. When I have ours hooked up to our '94 F-150 I needed a hitch bar that had a 4" drop to make it sit level. With my '13 Explorer, the hitch only has a 1" drop.
Pod People
Posted: 29 Aug 2017 at 11:35pm |
The shank is the part that fits into the receiver. The hitch is bolted to the shank. There are lots of shank sizes available in one inch increments to enable you to tow with the rpod as level as possible. Our Expedition uses a 7 inch drop shank in order to make the pod level. We use an Equalizer 4 way WDH and love it. Vann
Vann & Laura 2015 RPod 179
