  New Posts New Posts RSS Feed: SOLAR PANEL
Topic ClosedSOLAR PANEL
voisj View Drop Down
Direct Link To This Post Topic: SOLAR PANEL
    Posted: 14 Aug 2017 at 10:47am
Good answer all around.
No need to buy stuff unless you find a need for it. You will figure it out as you go. If you are just pulling into a Walmart for the night your TV (tow vehicle) should charge things up while you drive and solar wont help unless you stay the day with panels out or mount them to your roof.
100W Renogy Solar Suitcase. Mine keeps me charged up if there is good sun. Ebay $200
 I run 2 G24 (Stock) batteries, and get 4 days out of them with no solar, when I try. With solar we run the  fan vent (on 1) all night every night
When they die ( I'm trying) I will go for the twin 6v upgrade but so far power has not been an issue. I have a generator and solar and hardly ever run the generator.
I replaced my Television with a 12 volt one with a built in DVD player. So they are available and easy to find on Ebay. Then we had a power surge that killed it and now we run no television and I removed the antenna. Has changed the way we camp for the better.
cheers John
SLOPODMODS
John&Sue,SLO,CA
henryv View Drop Down
Direct Link To This Post Posted: 13 Aug 2017 at 3:30pm
Tars Tarkas....thanks, that was very helpful. Are you a NC Tarheel? I was born in Asheville...spent a summer in the Smokies a couple of years ago. Had a Jayco Kiwi then. Sold it and have a new R-pod 171 now and can't wait to get back to those cool mountains. I will take your advice and see how I like what I have already before over extending myself. But if I decide to go solar, the camper is solar ready, and I will probably get a 100W Renogy Solar Suitcase (although I googled cheaper brands). By the way, I grew up in Hickory, lived in Flat Rock for 30 years, and never been to the Outer Banks..I'm going to treat myself one of these days. I'm a retired Marine Corps captain with nothing but time on my hands.
Direct Link To This Post Posted: 13 Aug 2017 at 3:02pm
Direct Link To This Post Posted: 13 Aug 2017 at 2:56pm
Tars Tarkas View Drop Down
Direct Link To This Post Posted: 13 Aug 2017 at 2:35pm
Since you seemed to be talking about watching television on battery power I'm pretty sure Leo was asking if your television was 12v.  They used to exist back in the 30s maybe, but are there anything other than 12v trucks/automobiles anymore?
I got a 100W Renogy Solar Suitcase and am very pleased with it so far.  I've only used it for one week on the Outer Banks though.  That's a much different environment than Fall or Winter in the Smoky Mountains, where solar will be pretty much useless.  So think about where you will use yours if you get one.  There are cheaper ways out if you're up on Ohm's Law and a little handy, but the Renogy suitcase is pretty much plug and play.
As for whether to go for 2 x 6v batteries or stick with what you have, being cheap, I'd stick with what you have at least until the first sign of it failing or not keeping up with your needs.  What are you going to do with it otherwise?  With with a boost from solar it will let you camp for days on it's own.  I have 1 12v battery.  I also have a generator though.  I stay at Walmarts fairly often and would never hook up solar or a generator for that unless it's too hot to sleep without air con.  Solar does nothing for you there.
Unless you're planning on days away from shore power you don't need to make a snap decision about this, and even then, if it comes to it, you can charge your pod battery with jumper cables from your TV (tow vehicle).  Wait until you're comfortable with your understanding of the options and you have a better feeling for what you need for your kind of camping.  Some people (almost) always stay at commercial campgrounds with water, electricity, sewer, cable, swimming pools, miniature golf, and all sorts of other stuff and wouldn't have it any other way.  If that's you, solar panels will just waste space and money.
Direct Link To This Post Posted: 13 Aug 2017 at 11:39am
Footnote:How do I avoid overkill? Maybe the factory system I already have is sufficient. How do I know, short of experience?? I don't want to buy two golf cart batteries if the one I already have will do the trick. ??
Direct Link To This Post Posted: 13 Aug 2017 at 10:10am
also, if I go with 2 golfcart batteries, which ones, and capacity??
Direct Link To This Post Posted: 13 Aug 2017 at 10:08am
looks like tv is tow vehicle? I just googled suitcase solar kits and a lot came up. How do i pick a quality one for reasonable price?
Direct Link To This Post Posted: 13 Aug 2017 at 9:50am
When you say 12 volt tv are you talking about television??
frogpod View Drop Down
Direct Link To This Post Posted: 13 Aug 2017 at 1:37am
The tow vehicle can charge the pod.  If you are only stopping overnight at a Walmart there should be no problem.  It helps if the wire in the tow vehicle that goes to the recharge slot on the plug on the back of the tow vehicle is 10 gauge and not the usual 12 gauge.  If staying a few days without traveling, you may need to recharge using the tow vehicle a couple of times.  I installed an extra 12 v battery and can go several days without recharging.  If you have AC and need to use it off grid the only option is a generator.  I have a 3000 watt champion inverter generator which runs on propane that we use for recharging the battery.  Actually got the generator to run the fridge, freezers and Television in the house when there is a power failure.  It runs on natural gas, propane, or gasoline.  Solar is something we are considering......but it would be just to be more environmentally friendly, not because it is needed.
Leo and Tami
with Coltrane the Jack Russell Terrier
2003 Toyota Tacoma TRD
