Page 12> |
Bhfromme
Joined: 07 May 2017 Location: Maine Online Status: Offline Posts: 24 |
Topic: Amp DrawPosted: 11 Aug 2017 at 10:44am |
Okay this topic has probably been beat to death but can someone tell me how many amps a 2017 Pod draws just sitting with everything turned off?
The dealer is telling me it will draw 4 to 6 amps just sitting. Can that be right? If that's the case in two days my little Group 24 battery would be just about dead. Can that be? Bill |
Bill and Female Companion aka She Who Must be Obeyed
twodues
Joined: 31 Oct 2016 Location: Michigan Online Status: Offline Posts: 20 |
Posted: 11 Aug 2017 at 11:01am |
0.4 to 0.6 amps would be more likely. Dealer is way off!
Bhfromme
Posted: 11 Aug 2017 at 11:30am |
Thank you.
I have a cheap little volt meter and it showed a full charge of 100%. Then just sitting in the driveway with everything off it was down to 60% after just 24 hours. Something's not right, correct? |
Leo B
Joined: 13 Jan 2012 Location: Lyndonville, VT Online Status: Offline Posts: 4518 |
Posted: 11 Aug 2017 at 11:38am |
We usually throw ours on a trifle charger during down times or disconnect the battery to avoid any draining.
Leo B
Posted: 11 Aug 2017 at 11:39am |
Trickle charger. Curse of big fingers!
marwayne
Posted: 11 Aug 2017 at 11:43am |
The only thing that is on in our pod
plugged in at home is the CO/LP detector 11 watts |
sailor323
Joined: 11 Jun 2015 Location: S Central KY Online Status: Offline Posts: 281 |
Posted: 14 Aug 2017 at 7:39pm |
Our 2016 179 draws.1 amp just sitting. As far as I know, the only draws are the CO/propane detector and the radio
Posted: 14 Aug 2017 at 9:54pm |
Don't forget the thermostat and the refrigerator electronics.
Posted: 15 Aug 2017 at 7:22am |
Sailor,
.1A is pretty much solid in the average. 2-4A a day draw is why the pod can't sit for more then a week or so without damaging it's battery. Disconnect/remove the battery, or add a battery disconnect switch, if you can't stay plugged in. Our pod pulled .17A, but we had a couple mods that had a small continuous draw.
OP, if your battery is drawing down that far overnight, you have an issue. Either your battery isn't healthy, your battery isn't actually charged to 100%, or you have more draw then you should, possibly the antenna booster is on.. But, if your dealer said it draws 4-6A a DAY, then he is pretty close. If you have a Group 24, you have around 65aH available in a good battery, so figuring to stay above 50% soc to keep the battery healthy, 32/4 means in 8 days, the battery is being hurt. If you have already done that a couple times, your battery may already be toast. |
Bhfromme
Posted: 15 Aug 2017 at 2:29pm |
Ah ha! The antennae booster might be the culprit. How does one turn it on and off? I've looked for a switch but haven't seen it.
But if the TV is A/C only wouldn't the antennae and the booster be A/C only as well?? |
Page 12> |
