Page 12> |
fwunder
Topic: WiFi Ranger (on the cheap)Posted: 07 Jun 2017 at 5:09pm |
This was really just a proof of concept thing, but it worked out surprisingly well.
I have a bunch of Mac stuff (MacBooks and iDevices), a Google Chromecast, Fire Stick, Apple TV, etc., etc. I just wanted to see how far from WiFi source (sans phone Hotspot and cheaply and easily) I could make everything usable. I'm sure WifiRanger is very effective, but for the few times I want to use it, it's currently way out of my budget. I also didn't want to make a "pringles can" antenna or paperclip Yagi. I wanted something that worked out of the box. My MacBooks (2015+) actually have very good built in antennas. My MacBook's usable WiFi connection maxes out at about 200 feet from my primary home router (Airport Extreme) with little obstruction. To share the MacBook's WiFi connection I use a TP-Link N300 Travel Router. It works very well, is USB powered and all my devices have no problem connecting to it, sharing my MacBook Wifi connection. In this simple scenario, the MacBook is the WiFi extender for all the other devices. I wanted to see if I could (cheaply) push that further. I ordered a Alfa AWUS036NH 802.11n WIRELESS-N USB Wi-Fi adapter- 2 watt. It came with a small omni directional antenna which could easily be changed. I figured I would test it out to see how it compared with MacBook antenna. Not bad. My tests indicated it increase my bandwidth usability about 20-30 feet. I know it doesn't sound like much, but it encouraged me that the drivers and basic functionality was worth exploring. I then ordered a Alfa 7 dBi gain RP-SMA directional panel antenna. I walked to neighbors barn and pointed antenna back towards my home router. Doing some tests today, I have to say I was surprised. At a measured distance of 375 feet and through a bunch of trees I measured 10Mbps+ download and easily watched full screen streaming video. So, for less than $60.00, I significantly increased my WiFi capability (including router), all USB powered. Pretty cool. I'm convinced I could add a Yagi antenna and really stretch it out! Yes, I know that campground WiFi is mostly dependent on the campground bandwidth, how many campers are using it, what's in the way, etc. But, for $60.00 I figure I got a better chance than most and it's fun! fred ![]() ![]() |
M0tl3y
Joined: 21 Sep 2014 Location: Utah Online Status: Offline Posts: 61 |
Posted: 08 Jun 2017 at 8:04pm |
Great idea, thanks for testing it out. I've wanted to try something similar to extend my WiFi while traveling so I've ordered this from Amazon to try out.
The 178 club
PilotPodder
Posted: 22 Jul 2017 at 2:50pm |
It looks like you may have a USB to Ethernet converter in the picture to get the signal from the MacBook to the Travel Router? If so, is this a separate purchase?
fwunder
Posted: 22 Jul 2017 at 2:56pm |
Yes: https://www.amazon.com/gp/product/B00M77HMU0/
My MacBook doesn't have an ethernet port. If you don't mind sacrificing a USB port, this inexpensive adapter works fine. Otherwise, use a thunderbolt to ethernet adapter. fred
fwunder
Posted: 22 Jul 2017 at 3:15pm |
I just realized I also should have noted that in the picture above I have the travel router plugged into a 13000mAh USB charger. I always carry a couple of these for energy storage. Of course, if your laptop has an ethernet port and two USB ports, you would not need these additions.
Hope that helps. fred
Joined: 29 Jul 2009 Location: MD Online Status: Offline Posts: 9066 |
Posted: 27 Jul 2017 at 8:23pm |
panel antennas are great for gain, just keep in mind that they are very directional.
podenvy
Joined: 06 Jul 2015 Online Status: Offline Posts: 33 |
Posted: 31 Jul 2017 at 8:13am |
Wanted to thank you for posting this because sometimes have to work from the pod and we use a travel router too. I didn't think of using a TB dongle for ethernet!
I mainly use my phone as a hotspot but it drains the battery way too quickly.
2013 FJ Cruiser + 2015 rpod 179 HRE
Posted: 31 Jul 2017 at 9:07am |
Have you wired a USB charging port into your R-Pod? If so, you could plug your phone in when using it as a hotspot to keep from draining your battery too quickly. They, along with standard 12V power outlets, are easy to install. |
PilotPodder
Posted: 03 Aug 2017 at 7:54pm |
I don't think the 179s had the factory installed USB ports until 2017, but Belkin has a nice plug-in unit that I use as well the factory USB port in my 2017 179. I show this in my top 5 tech video (see link in signature). Also at Amazon search for: Belkin Surge Protector with USB Ports BST300 if you are interested. I really like the product.
J.M. |
Posted: 03 Aug 2017 at 9:29pm |
Our 179 is a 2016 model that was built early enough on that it is more of a 2015.5 model since it lacks some of the 2016 changes such as the flip foot and the stainless steel sink. I had to install my own 12V outlets and USB charging ports. It was nice that Forest River incorporated these into the newer models, much as they did a window in the door of the new ones which is also something I had to install myself.
Page 12> |
